Go to Post When your team becomes ubiquitous with the phrase "Always a bridesmaid, never the bride" - Peyton Yeung [more]
Unread 06-02-2014, 13:26
fsgond's Avatar
fsgond fsgond is offline
Why aren't you throwing balls?!
AKA: Anthony
FRC #5484 (Memento Vitam)
Team Role: Coach
Rookie Year: 2007
fsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant future
Re: Two regulators for one piston
Our team was looking at a similar question a few days ago. Originally I was going to go the route of 1 valve on each side of the actuator, one at 60psi and one at 10psi. We found that as other have suggested that the http://www.andymark.com/product-p/am-2032.htm would be an easier way of doing things with the same goal achieved. I think either would work fine, but you would need to follow the rules about multiple regulators, I believe that there are some additional restrictions, such as having another gauge.
Anthony Rubio
Co-Coach, Memento Vitam Team 5484, 2015-????
Mentor, Black Knights Team 135, 2009-2015
Student, Black Knights Team 135, 2007-2008
Unread 06-02-2014, 15:54
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
Please try the experiment. What you will find is that the pressure is identical on both sides of the needle valve. These devices restrict the movement of air by making the orifice smaller. They limit the maximum kinetic energy (flow) without changing the final potential energy (pressure).
A flow restriction could be what you want if you are happy with the maximum shooter distance and what you are trying to do is create a slow piston velocity for a shorter shot (soft pass).
It will not work for the original question where they were trying increase the maximum velocity by presenting different pressures to either side of the piston. Asymmetric pressure is valid if you require less force to reset the shooter than to make the shot. Less pressure on the exhaust side will limit the required exhaust flow (less air to move) and increase the velocity of the piston. To change the pressure, you need a pressure regulator.
Unread 08-02-2014, 23:13
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Originally Posted by gpetilli View Post
A flow control valve will do the opposite of what is desired. A flow control valve does not change the final pressure, but changes how fast the air can enter/leave the cylinder and therefor slows down the travel. He is trying to exhaust the air in the cylinder faster. Since we are limited by the diameter of the valve, he is trying to limit the pressure on the exhausting side, and therefor the amount of air that needs to be expelled. To move the piston, you need more pressure on one side than the other, which we do by venting one side - he is trying to start from a more favorable delta pressure.
I know what the OP wanted. I was merely expanding on Matt's post about the flow control valves. Thanks for the explanation.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
