Go to Post Are we really that close-minded that we have to insult other teams that deviate from what we percieve to be right? Giving an opinion and insulting someone are far from each other. - Amanda Morrison [more]
Unread 05-02-2014, 21:55
JakeE's Avatar
JakeE JakeE is offline
Shut up and program.
FRC #4127 (LoggerBots)
Rookie Year: 2012
JakeE is an unknown quantity at this point
Counting the amount of times a voltage is read?
I have been having a complete brain fart over how to program something I think should be really simple. Using a sequence, I want a button to start a motor, count the amount of times a certain voltage is read from our analog channel, and then stopping the motor. However, I have no idea how to count and reset the amount of times this voltage is read! Anyone have any ideas?
Unread 05-02-2014, 23:44
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Counting the amount of times a voltage is read?
Look up Analog Triggers. You can define a voltage range for an analog input channel, and pass the output of the trigger to a counter as if it were a digital input.
