Go to Post It's not all about the offensive "powerhouses", strategy is key. - smurfgirl [more]
Unread 06-02-2014, 14:03
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
Team Role: Coach
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
Using 4 joystick buttons with Case Statement
Dear CD,
I am trying to use 4 joystick buttons in conjunction with a case statement in order to select one motor speed but am not being successful.
My guess is that the execution order impacts the design and does not effectively allow me to select some options.
Can you recommend a design solution?
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
Unread 06-02-2014, 14:05
marccenter's Avatar
Team Role: Coach
Exclamation Re: Using 4 joystick buttons with Case Statement
Dear CD,
Yeah, it helps to post a picture in the initial email.
Name:	Joystick 4Button.png
Marc Center
Unread 06-02-2014, 14:22
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
I'm on the road so I cannot offer up examples, but I can comment on what you have.
The code you posted has a chicken/egg issue.
None of the Latches are guaranteed to have been set by the loops on the left, before being used in the case statement to the right.
The case statement code on the right happens simultaneously with the checks you are performing on the left.
As far as using joystick buttons to select a motor speed, you can do something like this. Add more buttons (one speed and one Select per new button) for more variations in speed.
It just remembers (latches) the speed associated with the last button pushed.
I can't tell if this is in line with how you are trying to employ the buttons.
Unread 06-02-2014, 14:23
Animal Control's Avatar
Animal Control Animal Control is offline
FRC #2345
Rookie Year: 2007
Animal Control is infamous around these partsAnimal Control is infamous around these partsAnimal Control is infamous around these partsAnimal Control is infamous around these parts
Could you be a little more specific, I'm a bit confused as to where some of the values are coming from. Also wouldn't it be easier to use a case structure with a choice of each value? Sorry if I'm not much help.
Unread 07-02-2014, 09:53
marccenter's Avatar
Team Role: Coach
Unhappy Re: Using 4 joystick buttons with Case Statement
Dear CD,
I can't figure out for the life of me why I cannot see the third button case while seeing cases 1, 2, and 4?
Please see pdf attachment.
My next set of experiments will use Mark's example above but I really think my latching button method using RS Bistable vi should work.
Thanks,
4 button Joystick Latch.pdf
Marc Center
Unread 07-02-2014, 12:44
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
You still have the race condition that Mark pointed out. Putting the latches in a sequence helps some, but doesn't keep the case statement from executing before or after the sequence.
I think you can implement the whole thing using wires and feedback nodes, and then you would have no race conditions.
As for any specific debugging, that's almost impossible to do with a PDF of a portion of the code, and hardly any description of what the code is supposed to do. Post the VI and a detailed description and maybe someone can help. To me, it looks overly complicated, but since I don't know what its supposed to do, I can't say for sure.
Unread 07-02-2014, 12:51
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
There's an awful lot of complicated stuff going on there. I suspect LabVIEW provides a much simpler way to do what you want, but without knowing what you want to do, I don't want to risk giving inappropriate advice.
What exactly are you trying to do here?
Unread 07-02-2014, 14:12
chris.boyle's Avatar
chris.boyle chris.boyle is offline
Programming Mentor
FRC #0068 (Truck Town Thunder)
Rookie Year: 2012
chris.boyle is on a distinguished road
If you are looking to create a latch on a variable, you can use this method:
It works very well for us and it only updates the variable when something changes. We use this method for almost all inputs from the driver station.
2014 Chairman's Award--Michigan State Championship
2014 Chairman's Award--Waterford District
2014 Winner--Great Lakes Bay District
2013 Chairman's Award--Kettering District
2012 Championship Division Finalists--Thanks 330 and 639
Unread 08-02-2014, 22:38
Doc Wu's Avatar
Doc Wu Doc Wu is offline
AKA: Al Gritzmacher
FRC #1507 (Warlocks)
Doc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant future
Originally Posted by marccenter View Post
Dear CD,
I wonder if the third button is generating a a value of 4 and your fourth button generates a value of 8?
When you convert a binary array to a number, each bit takes a power of 2 value. To get three, you'd need 1 and 2 simultaneously.
-= Mentor Lockport Warlocks -=- Team 1507 =-
Amateur Radio Callsign: AE2T
2015 Robot Inspector - Pittsburgh, Champs. Judge Observer - Champs
2014 Robot Inspector - Tech Valley, Fingerlakes, Buckeye, Championship
2013 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Website Evaluator - Fingerlakes, Buckeye, Championship
2011 Robot Inspector - Fingerlakes 2011 Safety Advisor - Fingerlakes
Unread 12-02-2014, 14:28
marccenter's Avatar
Team Role: Coach
Doc Wu,
That's it! I haven't tested it yet but I know that's the solution.
When I get a chance, I will post the problem and solution for CD reference.
Thanks,
Marc Center
