Go to Post ...the list of the things we want to get done in the off-season has grown to such a length that I have to take off my shoes and socks to count them...and I think I may need to grow a few more toes soon. - StephLee [more]
Unread 06-02-2014, 18:31
jordan11623's Avatar
jordan11623 jordan11623 is offline
FRC #4641
jordan11623 is an unknown quantity at this point
Unhappy Potentiometer, need help with programming
On our robot for the FRC Competition we have a axle on our grab arm. We'd like to wire a potentiometer to it so that we can control the voltage that goes in and out of it depending on which side it goes to. (Up or down, I guess). And we'd also like to know how we could get the input from that potentiometer and translate it to a program in LabView, whether manually or otherwise. We're not sure if that was explained correctly or in a way that makes sense. The team isn't exactly sure how to do this in any way. We'd like to stop the grab arm from going back down after we bring it up, we want it to lower manually but have it stop and lock automatically after we raise it.
-Team 4641
Unread 06-02-2014, 18:52
Team3266Spencer's Avatar
Team3266Spencer Team3266Spencer is offline
Team Captain and Lead Programmer
AKA: Spencer Lanman
FRC #3266 (Robots-R-US)
Rookie Year: 2012
Team3266Spencer is an unknown quantity at this point
Re: Potentiometer, need help with programming
You're better off using an encoder. You can mount an encoder to the shaft which will tell you, basically, the angle at which your arm is at.
2012: Buckeye Regional, Queen City Regional, Human Player
2013: Queen City Regional, Buckeye Regional, Crossroads Regional
Shooter Operator
2014: Crossroads Regional, Queen City Regional
Catapult Operator
2015: Georgia Southern Classic Regional (Winner), Queen City Regional
Chainsaw Operator
Want to talk? TeamSpeak: team3266.noip.me
Unread 06-02-2014, 18:58
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
You're definitely better using a potentiometer.
An encoder (most FRC 'encoders' are quadrature incremental encoders) tells you how far you have gone since your zero point.
A potentiometer tells you exactly where you are, but when you exceed the limits it will break.
There are also 'absolute encoders' which work just like a potentiometer, but roll over to the other end of their range when they hit their limits.
In any case, in LabVIEW, use an 'AnalogChannel' to measure the voltage of the potentiometer. Connect the pot's ends to the black and red wires (+5v and Gnd), and the wiper to the white wire (Signal). The voltage in on the analog module will be between 0 and 5v.
Once you have the position, you can scale it from volts to degrees, or whatever units you want, or leave it in volts. From there, you can run a control loop (search here for 'PID control') for your position control.
Kettering Motorsports
Unread 06-02-2014, 20:45
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Have you looked at the potentiometer example in the NI FRC examples?
I agree, a potentiometer is a much better choice for an arm then an encoder.
Unread 07-02-2014, 07:23
DELurker DELurker is offline
Former Engineering Mentor
AKA: William Lydick
no team (n/a)
Rookie Year: 2011
DELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant future
Agreed. A pot is the sensor to use in this application.
One note: Before you connect up your pot, use an ohmmeter and check the resistance range from the wiper (center) to one of the two outer pins across the entire range of motion. We have had problems in the past with people installing pots with 270 degrees of motion but only 60 degrees of resistance change. As soon as we replaced these joystick pots with normal ones (270 degrees of motion and 270 degrees of resistance change), a lot of things worked so much better.
With 1370 --
2012 Rutgers District Event Champions with 1676/56
2012 Lenape District Event Finalists with 2191/1691
2013 TCNJ District Event QuarterFinalists with 1143/4750, Gracious Professionalism Award
2013 Bridgewater-Raritan District Event Semi-Finalists with 4285/223
2013 MAR Championship Finalists (Backup) with 222/11/1403; Gracious Professionalism Award
