Go to Post Then there's the electronics, pneumatics, and all that stuff on top that will magically make the ball score billions of points. That will add up to a lot of weight. - MrForbes [more]
Unread 07-02-2014, 08:10
DMike
Posts: n/a
What is considered a catch
Are there any "possession, control" rules ? What if the ball passes over the truss and falls into a waiting "catching bot", but then bounces out. Is this considered a catch?
Unread 07-02-2014, 08:23
TheKeeg's Avatar
TheKeeg TheKeeg is offline
Michigan Tech Engineering
AKA: Keegan Harrington
FRC #0068 (Truck Town Thunder)
Rookie Year: 2013
TheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud ofTheKeeg has much to be proud of
Re: What is considered a catch
3.1.4:
A CATCH occurs when a BALL SCORED over the TRUSS by a ROBOT’S ALLIANCE partner is POSSESSED by that ROBOT before contacting the carpet, the ROBOT which SCORED the TRUSS, or HUMAN PLAYER.
The ref needs to see obvious possession before the ball hits the ground, i.e the ball cant just hit your catcher and bounce right out without you "holding" it first.
At least that is what i got from it.
Unread 07-02-2014, 08:36
JamesCH95's Avatar
JamesCH95 JamesCH95 is offline
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
JamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond repute
I would most certainly apply the 'grandmother' rule to this. That is to say if your grandmother (or someone unfamiliar with FRC and its detailed rules) wouldn't think a robot caught the ball, then you didn't really catch it.
If the ball lands in/on your robot and bounces out, that's probably not a catch.
Theory is a nice place, I'd like to go there one day, I hear everything works there.
Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot.
Unread 07-02-2014, 09:34
pntbll1313's Avatar
pntbll1313 pntbll1313 is offline
2052 Coach, Build/Electrical Mentor
AKA: Pete
FRC #2052 (KnightKrawler)
Rookie Year: 2007
pntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud of
Do not apply the 'grandmother' rule to this. There is a clear definition in the manual.
You just need to POSSESS the ball. DjScribbles has quoted the places in the manual and QA relevant to the definition of POSSESSION.
CATCH != catch as your grandmother may think.
2016 (mentor/drive-coach)
Quarter-Finalist-Einstein, Winner-Carson Division Champs, Winner-10K Lakes, Chairman's Award-10K Lakes, Finalists-Lake Superior,
Winner-MSHSL Robotics Competition
2015 (mentor/drive-coach)
Finalists-10K Lakes, Finalists-Lake Superior, Finalist-MSHL Robotics Competition, Quarter-Finalist-Galileo Division Champs
2014 (mentor/drive-coach)
Winner-10K Lakes, Winner-Lake Superior Winner-MSHSL Robotics Competition, Quarter-Finalist-Galileo Division Champs
2013 (mentor/drive-coach)
Winner-10K Lakes, Winner-Lake Superior, Winner-MSHSL Robotics Competition, Quarter-Finalist-Newton Division Champs
2012 (mentor/drive-coach)
Finalists-Lake Superior, Semi-Finalist-MSHSL State Championship, Semi-Finalists at 10,000 Lakes
2008-2011 (college mentor)
2007 (driver)
Quarter Finalist-Milwaukee
Unread 07-02-2014, 09:41
M.O'Reilly M.O'Reilly is offline
AKA: Mike O.
FRC #4637 (BambieBotz)
M.O'Reilly is a glorious beacon of lightM.O'Reilly is a glorious beacon of lightM.O'Reilly is a glorious beacon of lightM.O'Reilly is a glorious beacon of lightM.O'Reilly is a glorious beacon of light
2 feet down and a football move common to the game?
sorry, couldn't help it.
Unread 07-02-2014, 09:52
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
If you're willing to risk a non-reversible ref's call on it, go ahead.
I see a few ways to interpret what's in the manual:
"carrying" - passes the grandmother check
"herding" - if you can repeatedly bump/push the ball before it hits the ground, you deserve a medal
"launching" - Very high-risk IMO, relies on ref's non-reversible call/judgement being the same as yours with regards to a mechanism being in motion relative to the robot; you must also hit the ball mid-air with a moving mechanism which doesn't strike me as practical and would likely result in hunting down the ball, costing you and your alliance precious time. While possibly within the letter of the rule, it is not within the spirit or intent of the rule IMO.
"trapping" - if you can pin a ball between your robot and a field element mid-air, you deserve a medal, and i think that would also pass the grandmother rule too
So, I suppose you're right in a sense: there are a few cases where a by-the-letter interpretation of the rules results in a CATCH the grandmother rule does not. Though IMO one better think long and hard about the practicality and reliability of making a 'non-grandma-approved' CATCH. I suggest following the grandmother rule from a practicality and reliability standpoint.
Unread 07-02-2014, 10:11
pntbll1313's Avatar
AKA: Pete
Rookie Year: 2007
I didn't say anything about it being worth it to risk this. There are many threads out there from the beginning of the season arguing the ambiguity of a CATCH. I'm sure there will be quite a few refs that call a launch a CATCH, and quite a few that don't. That's one of the tough things about this particular rule. If you are a high caliber team you will of course try to design a mechanism capable of performing a CATCH and actually catching the ball for control reasons.
If you are a low resource team and were only able to field a moving lunch tray there are other ways to get a CATCH. If you have a spinning paddle on top of your robot designed to hit the ball in the forward direction all you need to do is park under where the ball will land. If the ball hits your paddle and goes forward it would, according to the manual and QA, be considered a CATCH. Grandma wouldn't think so because it is not a catch, but it is still a CATCH.
2007 (driver)
Unread 07-02-2014, 10:13
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
I'm not disagreeing with you, I think all of your points are valid, I am just explaining why I would choose to follow the grandma rule.
Sorry if my original post did not convey that intent
Unread 07-02-2014, 10:15
Josh Fritsch's Avatar
Josh Fritsch Josh Fritsch is offline
Team 27 Mentor/Alumni
FRC #0027 (Team Rush)
Josh Fritsch has a spectacular aura aboutJosh Fritsch has a spectacular aura about
Couldn't agree more. Both POSSESSION and CATCH are clearly defined within the rules and Q&A quoted above.
There is no reason to bring opinions on practicality and risk into the discussion as each team must weigh that on their own when designing mechanisms within the rules defined. The OP asked a specific question and the response given was correct.
Unread 07-02-2014, 10:23
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
Rookie Year: 2011
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
Something to keep in mind is that the same "possession" definition that applies to catching a ball coming over the truss also applies to possessing an opponents ball, which is a technical foul.
If you are prepared to argue that deflecting your own ball should count as a catch, you should also be prepared, as a matter of gracious professionalism, to argue that by deflecting your opponents ball you deserve a technical foul.
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
Unread 07-02-2014, 11:57
Duncan Macdonald's Avatar
Duncan Macdonald Duncan Macdonald is offline
Globe Motor Fan Club
FRC #0610 (Crescent Robotics)
Duncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond reputeDuncan Macdonald has a reputation beyond repute
Send a message via MSN to Duncan Macdonald
I anticipate the "desired location or direction" being called very strictly with regards to catching to prevent a team from spinning a baseball bat over their robot to earn catch points. If a robot has an active mechanism directing the ball towards the next zone/far wall/friendly robot reliably I expect catch points to be awarded. I am comfortable with my interpretation of the rule but it is slightly at odds with the traditional (grandmother's) definition.
My grandmother's opinion of the rules doesn't bother me this year since an "assist" could be:
-Robot Red 1 pins ball against wall for a couple of seconds
-Every robot ignores the ball for 90 seconds
-Robot Red 2 collects it, drives it the length of the field, and scores it
-Red robot 1 recieves the ball and throws it the length of the field
-Blue robot bumps it back to the original zone ("traditionally considered incomplete or a turnover)
-Red robot 2 collects and scores
Queen's Applied Science '13, Applied Mathematics
Unread 07-02-2014, 13:12
AFron10's Avatar
AFron10 AFron10 is offline
Mentor
AKA: Adrian Fronczak
FRC #3015 (Ranger Robotics)
Rookie Year: 2011
AFron10 will become famous soon enoughAFron10 will become famous soon enough
Sorry that this may be a little off topic but when a human player catches the ball over the truss, then places the ball in a robot without the ball ever touching the ground, does that alliance receive catch points in that cycle? I apologize if this is already stated in the Q&A or the manual.
Team 3015
2015 Newton Division Finalists (195, 1756, 4522)
2014 Curie Division Quarter-Finalists (624, 987, 3476)
2 Time Regional Champions (2012 Buckeye and 2015 Finger Lakes)
3 Time Regional Finalist
3 World Championship Appearances
Career Student Record: 76-24-0
Unread 07-02-2014, 13:23
BBray_T1296's Avatar
BBray_T1296 BBray_T1296 is offline
I am Dave! Yognaut
AKA: Brian Bray
FRC #1296 (Full Metal Jackets)
Rookie Year: 2010
BBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond repute
No, a catch by a human player is ineligible for catch points, however, when he (or she, I might add ) gives the ball to a [different] awaiting robot, assist points are received, along with the toss points.
Im not in a place to go scrounging through rules but I recall discussing this elsewhere on CD
If molecular reactions are deterministic, are all universes identical?
RIP David Shafer: you will be missed
Unread 08-02-2014, 11:34
Unsung FIRST Hero
Karthik Karthik is offline
VEX Robotics GDC Chairman
Rookie Year: 1998
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
I'm very interested in how this is going to be called at events this season. By the definitions and rules, this form of Trapping is Possession that would lead to an Assist. However, based on the comments of many volunteers, who are using the "grandmother rule", Trapping is not "enough" Possession to constitute an Assist. I hope that everyone is going to enforce the actual written rules, as opposed to this esoteric grandmother clause.
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
  #15   Spotlight this post!
Unread 08-02-2014, 12:42
It will be interesting from the standpoint of both offense - which I believe you are referring - as well as defense being played. If an opponent BLUE ball inadvertently gets trapped between the field side rail and a RED robot - even for a second, technically this is possession by the RED robot and a 50 point technical foul.
We'll see I guess.
