Re: What is considered a catch
POSSESSION is defined by the manual under G12 as follows:
Q177: Quote:
With the obvious overwhelming effort put into the rules and more rules. I would think that the definiton of "Catch" would be absolute. Ie. in possession for (X) amount of time, or mandatory movement of the bot after catching. Now we want to enact the vague "grandmothers rule", I would argue that inadvertently ending up with your opponents ball in your bot doesn't define possession, due to complete lack of intent. In fact are there any rules preventing an alliance from intentionally placing the ball in an opponents bot?
http://frc-manual.usfirst.org/ |
Yes, I missed that (G12) similiar to last years full court shooters, that sat in the loading zone only to move forward and create the technical foul. I witnessed this several times, with game changing consequences.
Let me pose this question.
You place a rotating bar on top of your robot. The ball is thrown over the truss it lands on your rotating bar and is "batted" somewhere on the field. Is this a catch? It would be a possession... the bar is moving relative to the robot... so this would be launching which is defined as possession. Granted you don't know exactly where the ball will be going but you should get the 10 points for a catch.. What say you? |
Yes, it would count as a CATCH. Whether or not it's called that way may be a different story. |
I tend to think it will be a judgement call by the referee If a robot had a giant bat on their robot that could hit the ball into the goal after the flight over the truss it should count as a catch. It would definitely count as a possession So what about a "foul tip". .?? Does it count as a possession if a robot hit a ball towards the goal? Why would "towards the goal" be the only "desired" location? I Think this needs to be further clarified. In my opinion the catch was "intended" by the game makers to be control of the ball and not a simple launch. In any sport a catch would mean control. I know that this is not any sport but we still need to think about what catching is in the context of its common usage The guy with the bat at the plate in baseball is not called the catcher. I believe this need to be clarified by the GDC. This will make the game easier to referee |
Q159 Q. If a blue bot deliberately (as determined by a ref) causes a blue ball to be POSSESSED by a red bot, will G12 apply or will G14 apply? If G14, and the POSSESSION is via carrying, can red POSSESS the ball for the remainder of the match without penalty? Consider if Red is not be able to free it. FRC2530 on 2014-01-17 | 7 Followers A. If it is determined to be a "strategy aimed solely at forcing the opposing ALLIANCE to violate a rule", G14 would be called. In this case, there would be no additional penalty for the Red ALLIANCE continuing to POSSESS the BALL. |
#10
A Blue bot on one side of the truss throws the ball over the truss to a Blue aliance member that is actively being defended from said catch by red defender.
The ball goes into the red bot, whats the call ? The Blue throwing bot is aware of the increased possibility that the ball will go into the red bot, but attempts the throw regardless. Is the Red bot penalized ? If yes, why would the Red bot accept the risk involed in defending the throw? |
#11
Is a bobbled and dropped catch still a legal catch?
A ball hits your robot in two places during a catch attempt, then spills out of the robot. Would that be considered herding, thus possession, thus a successful catch, even though the ball was never successfully "caught?" |
#14
Yesterday's update says no:
So from my interpretation, the new addition to "deflecting" means that the ball touches the robot, but then leaves after contact (eg. bounces in and goes out), wouldn't be considered possession.
However, wouldn't "Herding" be considered possession if the ball bounces inside the robot multiple times, as used in the definition of herding? Therefore if the ball bounces inside the robot a few times and then bounces out, wouldn't it legally be called possession by herding, and thus catch points? |
