Go to Post Of course, someone who can score on all rack levels while hovering autononmously 12 inches off the floor in his own home zone could probably have posted on CD while winning a regional.;) - Richard Wallace [more]
Unread 07-02-2014, 12:08
Mr. 1033's Avatar
Mr. 1033 Mr. 1033 is offline
AKA: Paul E. Lathrop
FRC #1033 (Team CLUTCH)
Team Role: Coach
Mr. 1033 is a jewel in the roughMr. 1033 is a jewel in the roughMr. 1033 is a jewel in the roughMr. 1033 is a jewel in the rough
Mec wheel help
I was wondering if anyone could point me to some basic, working C++ mecanum drive code. We have successfully compiled and deployed code using the cartesian and polar mecanum drive methods, but our robot behaves in unexpected ways when we try to run the code in teleop.
First, the robot's wheels start moving before the joystick is even touched by the drivers. Then, when they do push forward and back and left and right on the joystick, is seems to have no effect on the drive train.
We're using the 3 D joystick.
We aren't sure if we are sending bad values in the code, or if we have hardware or wiring issues.
[Note: the robot ran fine using robot drive code with one joystick in arcade mode, so we're stumped.]
Any help would be greatly appreciated.
Unread 07-02-2014, 12:22
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: Mec wheel help
Was the only difference between the red and green the mec vs arcade drive code? Or are there other differences (even non-drivetrain-related code)?
Unread 07-02-2014, 12:47
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Mec wheel help
We don't have much to base our help on. Show us your drive code and we'll be happy to suggest things to look at.
That your motors move before you tell them to is worrisome. I would suspect a wiring issue, except that you say it worked with Arcade Drive.
Unread 07-02-2014, 16:57
Halo_Kid_3633's Avatar
Halo_Kid_3633 Halo_Kid_3633 is offline
FRC #3633 (Catayst)
Rookie Year: 2012
Halo_Kid_3633 is an unknown quantity at this point
Re: Mec wheel help
We are having the same issues.
haha
- Yup Me
Unread 09-02-2014, 14:10
Toa Circuit's Avatar
Toa Circuit Toa Circuit is offline
Thaddeus Maximus
AKA: Thad Hughes
FRC #4213 (MetalCow Robotics)
Team Role: Leadership
Rookie Year: 2012
Toa Circuit is an unknown quantity at this point
Re: Mec wheel help
Sounds like:
Bad joysticks
or
Joysticks being moved before plugged in (When you plug in a joystick, most axes home themselves upon power on).
2012 Head of Programming and Electrical
2013-14 Overall Team Captain and Programming Head
2012-14 Mentor of FLL Team Power Surge
2014 Dean's List Finalist
2014 CIR Xerox Creativity Award
Webpage
Unread 14-02-2014, 02:22
TheVoid's Avatar
TheVoid TheVoid is offline
C++ programmer
AKA: Liam Taylor
FRC #2605 (Sehome Seamonsters)
Rookie Year: 2011
TheVoid is an unknown quantity at this point
Re: Mec wheel help
Hi there, just in case:
What sort of motor driver setup are you using? Is it closed loop? (If so, did you change anything about that too?)
As well, could it be that something besides your drive code is trying to set your motor controllers?
Finally, if you put the robot into any other enabled mode than Tele-operated, does this behavior show up? ( I suppose you would want to use Test mode for this )
"Just look for the rectangle. Simple!"
