Go to Post Edison was once asked "how do you come up so many good ideas?" to which he responded "for every good idea, I have 99 bad ideas first." - dlavery [more]
Unread 07-02-2014, 16:11
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
Team Update 2-07
General Updates
The 2014 Inspection Bill of Materials (BOM) Template has been posted on the Game Manual homepage.
The Shipping Crate Construction document has been updated on the Game Manual homepage.
Section 3.1.2: MATCH Logistics
If an ALLIANCE’s BALL becomes stuck in an ALLIANCE’S ROBOT, the ALLIANCE may signal to the Head Referee that the BALL is “dead” (specifics regarding the signaling process are yet to be determined). At this point, the Head Referee will suspend the CYCLE (TRUSS and CATCH points are maintained, ASSIST accruals are voided) and re-illuminate the PEDESTAL, beginning another CYCLE for that ALLIANCE. If the ALLIANCE has not yet begun a CYCLE, the Head Ref will illuminate the PEDESTAL to begin the first CYCLE for the ALLIANCE. If the dead BALL is freed, that BALL must be removed from the FIELD through one of the ALLIANCE’S GOALS or by passing to an ALLIANCE HUMAN PLAYER before the ALLIANCE can earn any more points. Each ALLIANCE is allowed to indicate one (1) BALL as “dead” per MATCH.
Section 3.2.3: General Rules
G12
An ALLIANCE may not POSSESS their opponent’s BALLS. The following criteria define POSSESSION :
“carrying” (moving while supporting BALLS in or on the ROBOT or holding the BALL in or on the ROBOT),
“herding” (repeated pushing or bumping),
“launching” (impelling BALLS to a desired location or direction via a MECHANISM in motion relative to the ROBOT), or
“trapping” (overt isolation or holding one or more BALLS against a FIELD element or ROBOT in an attempt to shield them).
Violation: TECHNICAL FOUL per instance. If extended, another TECHNICAL FOUL. If strategic, RED CARD for the ALLIANCE.
Examples of BALL interaction that are not POSSESSION are
A. “bulldozing” (inadvertently coming in contact with BALLS that happen to be in the path of the ROBOT as it moves about the FIELD) and
B. “deflecting” (a single hit to or being hit by a BALL that bounces or rolls off the ROBOT or a BALL slips through the grips of a ROBOT without arresting the BALL'S momentum).
A BALL that becomes unintentionally lodged on a ROBOT will be considered POSSESSED by the ROBOT. It is important to design your ROBOT so that it is impossible to inadvertently or intentionally POSSESS an opponent’s BALL.
Section 3.2.6: ROBOT-ROBOT Interaction
G29
An ALLIANCE may not pin an opponent ROBOT for more than five (5) seconds. A ROBOT will be considered pinned until the ROBOTS have separated by at least six (6) ft. The pinning ROBOT(S) must then wait for at least three (3) seconds before attempting to pin the same ROBOT again. Pinning is transitory transitive through other objects.
Section 4.5: Material Utilization
R18
At an Event, Teams may have access to a static set of FABRICATED ITEMS that shall not exceed 30 45 lbs to be used to repair and/or upgrade their ROBOT. Items made at an Event do not count towards this weight limit.
For Teams attending 2-Day Events, these FABRICATED ITEMS may be used during the Robot Access Period and/or brought to the Event, but the total weight may not exceed 30 45 lbs. FABRICATED ITEMS constructed during the Robot Access Period and bagged with the ROBOT are exempt from this limit.
Items exempt from this limit are:
the OPERATOR CONSOLE,
BUMPERS, and
any ROBOT battery assemblies (as described in R5-A).
Section 4.6: BUMPER Rules
R21-D
BUMPERS must be constructed as follows (see Figure 4-8):…
be covered with a rugged, smooth cloth.
Silk or bedding are not considered rugged materials. 1000D Cordura is recommended. Tape (e.g. gaffer's tape) matching the BUMPER color is allowed to patch small holes on a temporary basis.
Section 4.8: Power Distribution
R31
The only legal source of electrical energy for the ROBOT during the competition, the ROBOT battery, is one of the following approved 12VDC non-spillable lead acid batteries:
Enersys (P/N: NP18-12)
MK Battery (P/N: ES17-12)
Battery Mart (P/N: SLA-12V18)
Sigma (P/N: SP12-18)
Universal Battery (P/N: UB12180)
Power Patrol (P/N: SLA1116)
Werker Battery (P/N: WKA12-18NB)
Power Sonic (P/N: PS-12180 NB)
Yuasa (P/N: NBP18-12B)
Gaffers tape is legal to patch bumpers.
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
Unread 07-02-2014, 17:36
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
Re: Team Update 2-07
The way I read that update, the following could occur, which I don't think the GDC intended:
Three balls are pre-loaded, none of them are scored in autonomous. One is picked up during teleop, and gets 'stuck.' Alliance declares ball dead. Two balls are still rolling on the field. Ref lights up pedestal to start the first cycle. This is consistent with the update.
I suspect they should have said the ref won't light it up until all autonomous balls are either scored or declared dead (of course, only one can be declared dead.)
In the mean time, if you want to get a cycle going early after having a bad time at Auto, just load one ball and declare it dead.
Even if that fix is made, the following scenario is possible:
One ball is left unscored after auto, and rolls to the far end of the field, so that it needs to be taken across the field to score. (No humans are stationed nearby) A working robot could load the ball, declare it dead so that a higher scoring ball (the cycle ball) can be introduced and then score the dead ball (for no points) after making the cross field trip. Meanwhile, the new cycle ball is already inbounded and maybe had toss/catch points before the dead ball is cleared off the field.
What if a dead ball comes loose and finds its way into the opponent's low goal via an unlucky bounce? That is not an approved way to clear a dead ball (must be only by giving it to human or putting it into the alliance's goal.) So technically, this is equivalent to a second stuck ball and the team is done scoring for the match.
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
Unread 07-02-2014, 18:55
Lil' Lavery Lil' Lavery is offline
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Lil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond repute
Send a message via AIM to Lil' Lavery
45lb.s worth of witholding allowance?!
A full 50% increase over what we had previously, up to nearly 40% of our total weight. Wonder if this is motivated by the worse than usual snow delays that have hammered much of the east coast.
Unread 07-02-2014, 18:57
Chris_Ely's Avatar
Chris_Ely Chris_Ely is offline
AKA: luckof13
FRC #3414 (HackBots)
Rookie Year: 2010
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
Yes it was. See the 2/5 blog.
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 07-02-2014, 19:58
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Sorry, you lose track of things when you're in the middle of the ocean for a few days.
Unread 08-02-2014, 09:22
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Another problem solved by Frank in a fairly uniform, easy to enforce, fair way to deal with the random bad weather. Slight penalty to teams that spend the first hours bolting on the extra parts but a big win overall.
Another plus 1 for Frank and his team. Could this be the start of a wave of simple, common sense like solutions sweeping across the nation?
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
