Go to Post Robotics is fun, but it isn't the most important thing in life. - Wayne TenBrink [more]
Unread 07-02-2014, 17:02
Doris Arias Doris Arias is offline
FRC #0564
Doris Arias is an unknown quantity at this point
Battery voltage on dashboard.
We are having problems getting our dashboard to display the voltage of the battery, we think we have the code right but the value isn't being printed, any suggestions? we think it might be a wiring issue.
Unread 07-02-2014, 17:08
MrForbes's Avatar
MrForbes MrForbes is online now
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Battery voltage on dashboard.
Did you connect an anlog input to the power distribution board, so it has something to measure?
Unread 07-02-2014, 17:13
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
What wiring do you think you need in order to read the battery voltage? What programming are you doing in order to send it to the dashboard, and what are you doing in order to display the value that is sent?
But most importantly, why do you want to show the battery voltage on the dashboard? It's already prominently displayed on the Driver Station.
Unread 07-02-2014, 19:56
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
The 2014 version of the analog breakout board does not have a jumper. And no place to put one.
Unread 07-02-2014, 21:24
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Good to know. Thanks Frank.
Unread 07-02-2014, 23:07
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
FRC #1296 (Full Metal Jackets)
wireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond reputewireties has a reputation beyond repute
Send a message via AIM to wireties
Ditto - thanks for the heads up Frank!
Fast, cheap or working - pick any two!
Unread 07-02-2014, 23:12
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Doris,
The number one problem here is the failure to wire a 12 volt output of the PD to the analog module. Following that, on pre-2014 analog modules, is the insertion of the jumper on the left edge of the module.
Al
WB9UVJ
www.wildstang.org
________________________
