Go to Post Moat confirmed, he was only mostly wrong - swnylm [more]
Unread 08-02-2014, 08:05
TheHolyHades1 TheHolyHades1 is offline
Rookie Year: 2010
TheHolyHades1 is a jewel in the roughTheHolyHades1 is a jewel in the roughTheHolyHades1 is a jewel in the rough
How to attach hub to window motor
Hello.
We currently have the black plastic hubs that fit onto the shaft of the denso window motors.To attach them, we have previously used holes drilled through the shaft with a pin of some sort to attach the two. However, I think that this isn't the best solution and I was curious what other ways (if any) you guys used to attach those black plastic hubs, apart from solely friction. It seems as though there are small holes drilled into the plastic star shape around the shaft on the window motor - should these be used for screws?
Thanks.
Unread 08-02-2014, 09:17
MetalJacket's Avatar
MetalJacket MetalJacket is offline
Has read the 2014 manual
AKA: Jesse Gibson
FRC #2068 (The Metal Jackets)
Team Role: CAD
Rookie Year: 2011
MetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura about
Re: How to attach hub to window motor
We tend to drill into the hubs and tap holes for 10-32 screws that we use as setscrews. I could grab a picture for you at our meeting today if you'd like.
Team Role = !artTeam
2011 - Logomotion
- Virginia Regional : Tournament Semi-Finalist, Gracious Professionalism Award
2012 - Rebound Rumble
- Chesapeake Regional : Tournament Finalist, Gracious Professionalism Award
2013 - Ultimate Ascent
- Virginia Regional : Gracious Professionalism Award
Unread 08-02-2014, 12:57
swwrobotics's Avatar
swwrobotics swwrobotics is offline
FRC #2900 (The Mighty Penguins)
Team Role: Mechanical
Rookie Year: 2011
swwrobotics is an unknown quantity at this point
Last year we used the window motor with the hub mounted upside-down for our cam shooter. Obviously it would have been a problem if the hub on the motor had no firm grip so we just used superglue and it worked fine! (but then you're probably left with a permanently attached hub )
Unread 08-02-2014, 20:47
Jibri Wright's Avatar
Jibri Wright Jibri Wright is offline
FRC #1781 (Electric Eagles)
Team Role: CAD
Rookie Year: 2011
Jibri Wright will become famous soon enough
In the past, we just would machine a plate that would sandwich with whatever the Denso motor would attach to. This however is a bit more work and machining a hole the size of the shaft holder can't be easily done without help from a machine shop unless you have a drill bit that big
You know someone likes something when after doing it a million times, they still marvel at it as if it was the FIRST.
Greatness asks how can I make it better. Genius asks how can I make it different.
