Go to Post All I know is that last year in Philadelphi, our camera locked dead onto MOE (Team 365) and their flourescent green shirts during the matches. They might want to consider what would happen if they get pelted with balls during the autonomous period! :ahh: - Greg Marra [more]
Unread 02-08-2014, 06:12 PM
Joey1939's Avatar
Joey1939 Joey1939 is offline
AKA: Joey Holliday
FRC #1939 (Kuhnigits)
Rookie Year: 2014
Joey1939 has a spectacular aura aboutJoey1939 has a spectacular aura aboutJoey1939 has a spectacular aura about
Motor Moving While Set To Zero
We have a motor connected to a talon. In our code the Talon should always be set to full speed forwards/backwards or zero/off. Moving the motor forward or backwards works perfectly, but whenever the motor should be set to zero/off, it continues to move backwards slowly. Any insight would be greatly appreciated.
Here is part of the code for reference:
Code:
public class OI {
    public JoystickButton rollersIn;
    public OI() {
        rollersIn = new JoystickButton(rotateStick, 1);
        rollersIn.toggleWhenPressed(new RollersInCommand());
Code:
public class  RollersInCommand extends Command {
    public RollersInCommand() {
        requires(Robot.arm);
    protected void initialize() {
        Robot.arm.rollersIn();
    protected void execute() {
    protected boolean isFinished() {
        return false;
    protected void interrupted() {
        Robot.arm.rollersStop();
Code:
public class Arm extends Subsystem {
    SpeedController motor = RobotMap.armmotor;
    public void initDefaultCommand() {
    public void rollersIn(){
        motor.set(-1.0);
    public void rollersOut(){
        motor.set(1.0);
    public void rollersStop(){
        motor.set(0.0);
Unread 02-08-2014, 06:21 PM
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: Motor Moving While Set To Zero
What is the LED on the Talon doing when it is moving slowly?
Unread 02-08-2014, 09:19 PM
heuristics heuristics is offline
FRC #3634
Rookie Year: 2014
heuristics is on a distinguished road
Try calibrating your Talon.
Unread 02-09-2014, 12:42 PM
Joey1939's Avatar
AKA: Joey Holliday
Rookie Year: 2014
The light is slowly flashing red.
Okay. Thank you. I think that this will probably fix it.
