Go to Post Winning or losing on the field has nothing to do with this success. - E. Wood [more]
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Unread 08-02-2014, 19:06
chigskonkwo chigskonkwo is offline
FRC #0884 (Mechanical Mules)
Rookie Year: 2011
chigskonkwo can only hope to improve
Relay Solenoid vs. Double Solenoid? Double Solenoid Wired to Relay in DSC.
What is the difference between a relay solenoid and a double solenoid? Can regular double solenoids be wired to the relay in the digital sidecar if it is programmed this way, such as what is here where it says "Relay Solenoid Example" here?
http://team358.org/files/programming...2009-/LabVIEW/
Last edited by chigskonkwo : 08-02-2014 at 19:21. Reason: Obtained more information.
Unread 08-02-2014, 19:13
JamesCH95's Avatar
JamesCH95 JamesCH95 is offline
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
JamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond repute
Re: Relay vs. Double Solenoid?
A relay, like a spike, is very different from a single- or double-acting solenoid.
If you're interested in the difference between single-acting and double-acting solenoids it's pretty simple: a double-acting solenoid is stable in whatever state it is in, whereas a single-acting solenoid always reverts to one particular state unless it is energized.
Theory is a nice place, I'd like to go there one day, I hear everything works there.
Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot.
Unread 08-02-2014, 19:21
Rookie Year: 2011
Re: Relay Solenoid vs. Double Solenoid? Double Solenoid Wired to Relay in DSC.
So what is meant here where they have "Relay Solenoid Example"?
Unread 08-02-2014, 19:29
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
I'm no lab-view expert, but it looks like they're driving a solenoid with a relay (Spike) instead of the solenoid break-out-board. This was the only option before solenoid break-out-boards existed, and useful for driving multiple valves at the same time in the same direction.
Unread 08-02-2014, 20:40
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
12v solenoids can be run via Spikes (Relays in code) in place of using the Solenoid Module.
Only 12v solenoids can work this way.
Wiring goes like this for Single Solenoids:
Wiring like this for Double Solenoids (each solenoid block just represents one side of the Double Solenoid):
Unread 08-02-2014, 20:44
Rookie Year: 2011
Oh okay, so just to clarify, there is no way to do this with 24v solenoids?
Unread 08-02-2014, 20:46
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
Spikes will most likely fry if you try to run them off of 24v. You need to use the Solenoid breakout board.
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Speaking from personal experience, a Spike will blow up if powered with much more than 14V.
Unread 08-02-2014, 20:50
Rookie Year: 2011
Oh okay thanks, it's just that we are experiencing problems with our Solenoid Module/Solenoid Breakout/Code/cRIO (we don't know what exactly the problem is) and are looking for any other way to power our solenoids.
Unread 08-02-2014, 20:53
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
There are some specifics about 24V solenoids in the 2014 manual, blue box on [R42] states a power limit for the solenoid breakout board, you should ensure that your solenoids aren't over-powering it.
Unread 08-02-2014, 21:05
Rookie Year: 2011
The solenoids that we are using are the same solenoids that we used last year with no problem, with the same cRIO, Solenoid Module and Solenoid Breakout.
Unread 08-02-2014, 21:10
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
Rookie Year: 2013
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Are you regulating your pressure properly? This year our solenoid did not work at all because we had our regulator set to over 100 psi versus the max of 60 psi.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
