Go to Post If sponsors are only interested in blue banners and trophies, then they don't get it. - Taylor [more]
Unread 09-02-2014, 02:14
Zmarken Zmarken is offline
FRC #1716 (Redbird Robotics)
Rookie Year: 2012
Zmarken is an unknown quantity at this point
Re: First Programming - Victor/PWM help
Originally Posted by popnbrown View Post
Lights were lit with the ribbon cable in, does taking it out have any effect on these three lights? Shouldn't it only have an effect on the RSL light?
Some people say that small amounts of power can be transferred through the ribbon cable, enough to have all 3 lights be lit, but when the cable's pulled out, only 2 lights are lit. I haven't had first-hand experience with that though.
Unread 09-02-2014, 12:12
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
If the Digital Sidecar is properly connected to power, then having the ribbon cable removed should not affect its power LEDs. That's why disconnecting the cable is a good diagnostic for DS power issues.
If the big orange Robot Signal Light is blinking, it usually means battery voltage is getting to the Digital Sidecar okay.
Unread 09-02-2014, 12:20
popnbrown's Avatar
popnbrown popnbrown is offline
FIRST 5125 HOTH Lead Mentor
AKA: Sravan S
FRC #5125 (Hawks on the Horizon)
Rookie Year: 2007
popnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond repute
I'll try to remove it anyways just to double check but the RSL is working as it should for disabled and teleop.
I am an employee of FIRST. However, the postings on this site are of my own perspective as a FIRST mentor and volunteer and do not necessarily reflect the views of FIRST.
FIRST Team 5125 Hawks on the Horizon Lead Mentor
FRC Team 4096 Ctrl-Z Former Mentor
FTC Team 5203 #19@! Former Mentor
FRC Team 1403 Cougar Robotics Alumni
