Go to Post But now the most important question - is there a practical application for one of these devices on a FIRST robot? - Chris Fultz [more]
Unread 09-02-2014, 12:37
cad321 cad321 is offline
Jack of all trades, Master of none
AKA: Brian Wagg
FRC #2386 (Trojans)
Rookie Year: 2012
cad321 is just really nicecad321 is just really nicecad321 is just really nicecad321 is just really nice
custom vex shifter enclosures
My team this year gave me the task of making a custom enclosure for the vex two speed ball shifter. We attempted to do this last year for our pto but failed to receive a critical dimension causing us to slip into neutral. We have just finished assembling our shifters this year (with the custom enclosure I made) and upon installing them, realized we're having the same issue. The small little shaft sitting inside the shifter mechanism when the piston is retracted, is causing the ball bearings to sit just on the edge of the chamfer.Click image for larger version
When we rotate the wheel with our hand and no pressure is in the cylinder, the shifter slips into neutral. This is not the case when the shifter is in high gear (piston extended) Click image for larger version
This proves to us that the standoffs the piston sits on is the wrong length. Does anyone here have any ideas on how to fix this or better yet, the proper spacing between the piston and the first gear?Click image for larger version
Name:	critical dimension.jpg
Unread 09-02-2014, 16:52
Rstrzelecki Rstrzelecki is offline
FRC #0135 (The Black Knights)
Team Role: Mechanical
Rookie Year: 2012
Rstrzelecki is an unknown quantity at this point
Re: custom vex shifter enclosures
we ran into this problem when upgrading to a larger bore cylinder for our winch. We simply replaced the standoffs with ones that were the correct length. They are the same standoffs that come in vex kits, we used the 3" ones and cut them down to the right length and re tapped the one end.
Paul Copioli's Avatar Unsung FIRST Hero Woodie Flowers Award
Paul Copioli Paul Copioli is offline
President, VEX Robotics, Inc.
FRC #3310 (Black Hawk Robotics)
Rookie Year: 2000
Paul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond repute
The drawing with the dimension you need is in the following document:
http://content.vexrobotics.com/vexpr...ce-Drawing.PDF
In full disclosure I am the President of VEX Robotics, a division of Innovation First International.
