Go to Post "If you abuse the easy button, you become it." / "What does that mean?" / "We hit you and you say 'That was easy'" - ScoutingNerd175 [more]
Unread 09-02-2014, 14:28
katsauga's Avatar
katsauga katsauga is offline
Lead Programmer
AKA: Marshall Baskin
Rookie Year: 2011
katsauga has a little shameless behaviour in the past
Problems with startup build
I have attempted several times to run the FRC Boot-Up Deployment in Labview, and each time, it says successful. But when I go to the driver station, the robot code is not deployed upon startup and I must manually deploy it via robot main. does anyone know why this is?
If life gives you lemons,Make grape juice and sit back and watch the world wonder how you did it
Unread 09-02-2014, 14:29
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Rookie Year: 2011
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
Re: Problems with startup build
Could you post a screen recording of your workflow deploying the code?
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 09-02-2014, 14:31
katsauga's Avatar
Lead Programmer
Rookie Year: 2011
so you would like to record me running the Boot Up deployment?
Unread 09-02-2014, 14:42
xXhunter47Xx's Avatar
xXhunter47Xx xXhunter47Xx is offline
Lord of Lazy
AKA: Austin $wagmaster1337
FRC #4738 (Patribots)
Rookie Year: 2013
xXhunter47Xx will become famous soon enough
I think I had that same problem.
Do you just deploy it from RobotMain.vi? Because that's just debug mode, the cRIO won't retain the code.
You have to build the code and then run it as startup.
Go to build specifications on your main project page.
Click it, then right click FRC Bootup Development or something along those lines
Click build (doesn't have to be connected to build)
Once it's built, connect to the robot, right click it again and this time don't click build click run as startup.
Once it's deployed it will prompt you to reboot the cRIO. Power cycle the robot.
It should work now.
Unread 09-02-2014, 14:43
Whippet's Avatar
MIT Class of 2020
AKA: Luis Trueba
Rookie Year: 2011
Yes, you may be forgetting a step or two causing the problems. The recording would make it easier to identify the problem.
[EDIT]: Or try it exactly as xXhunter47Xx said to. If it doesn't work like that, it may be a problem with your cRIO image.
