Go to Post Yes, machining a dog profile into a steel sprocket on a manual mill was an experience filled with pain and regret. - Joe G. [more]
Unread 09-02-2014, 17:14
Killian2313's Avatar
Killian2313 Killian2313 is offline
FRC #2389
Killian2313 is an unknown quantity at this point
Exclamation Power distribution board help.
Team 2389 here, how do you hook up more than 8 Motor controllers to a Power distribution board?
Unread 09-02-2014, 17:16
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: Power distribution board help.
You can hook motor controllers up to 20 or 30 amp circuit breakers. Just be aware that those motors won't have as much current available... you'll want to use the 2014 motor data sheet provided by FIRST to help you decide which motors to put on which breakers to avoid tripping them.
2007 - Present: Mentor, 2177 The Robettes
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016; Galileo 2016; Iowa 2017
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
Unread 09-02-2014, 17:18
jwallace15's Avatar
jwallace15 jwallace15 is offline
What am I going to do with my life?
AKA: Wally
FRC #0068 (Truck Town Thunder)
Rookie Year: 2013
jwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud of
There shouldn't be an issue doing this. There are 19 open ports for motors (18 if you are using pneumatics, as your compressor needs to go on as well).
J Wallace IV
Truck Town Thunder
Just a college student now.
Unread 09-02-2014, 17:24
FRC #2389
I was under the impression that a motor controlor (like a tolon or vex) had to be hooked up to the 40 amp breakers.
Unread 09-02-2014, 17:29
jwallace15's Avatar
AKA: Wally
Rookie Year: 2013
It all depends on what kind of current the motors will be drawing. For example; it's a better idea to put your drive motors on a 40 amp breaker than 20 amp ones since they will typically draw the most current.
That being said, keep in mind Table 4-3 from the game manual; You have to use a minimum wire size depending on what breaker you put in the circuit.
J Wallace IV
Truck Town Thunder
Unread 09-02-2014, 17:37
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Rookie Year: 2012
Gregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond repute
Running motors off <40A circuits is ok. Be sure to pay attention to the table in R47.
Not quite. The PDB has 20 standard 12v ports. The sidecar needs 1, the analog breakout on the CRIO needs 1.
If you're running pneumatics, the compressor needs one, and most likely the solenoid breakout needs one too (since most teams run 12v solenoids off the analog breakout).
What are nationals? Sounds like a fun American party, can we Canadians come?
“For me, insanity is super sanity. The normal is psychotic. Normal means lack of imagination, lack of creativity.” -Jean Dubuffet
"Insanity is doing the same thing over and over again and expecting different results." -Albert Einstein
FLL 2011-2015 Glen Ames Robotics-Student, Mentor
FRC 2012-2013 Team 907-Scouting Lead, Strategy Lead, Human Player, Driver
FRC 2014-2015 Team 1310-Mechanical, Electrical, Drive Captain
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 09-02-2014, 17:42
jwallace15's Avatar
AKA: Wally
Rookie Year: 2013
Originally Posted by Gregor View Post
The sidecar needs 1.
That's why I said 19 open ports. I didn't think about having the solenoid breakout on 12V either, as I remember using 24V for it last year.
Edit: I didn't know about the analog breakout board though.
J Wallace IV
Truck Town Thunder
Unread 09-02-2014, 17:44
Gregor's Avatar
Rookie Year: 2012
And every team also needs to power the analog breakout.
<Since 2011
Unread 09-02-2014, 19:15
DonRotolo's Avatar
Back to humble
FRC #0832
No, any motor controller can always be used with a smaller breaker. Just note that certain motors MUST use a motor controller, while others may use one or a Spike relay (at your option).
