Go to Post Stand strong mentors. You never know who you have become a brother, sister, father, or mother to. - MysterE [more]
Unread 09-02-2014, 20:25
jordan11623's Avatar
jordan11623 jordan11623 is offline
FRC #4641
jordan11623 is an unknown quantity at this point
Solenoid issues
I am struggling with a really weird issue the solenoids i programmed in labview sometimes work and sometimes they don't ( I check the led status lights on the C-rio and the Solenoid break up board and they don't always light up) one of my teammates thinks it is a electrical issue while i think its a programming issue please look at my programing and tell my what i am missing
Begin vi
Teleop
vi
finish
vi
Unread 09-02-2014, 22:28
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Solenoid issues
Your solenoid functions in Begin are riddled with red "coercion" dots. They're telling you that you have something wired to them that they aren't expecting, but the values are compatible enough that the function thinks it can make it work. Whether or not it actually will work is unclear from the pictures.
Where did you get the enumerated constants you're using? I think you should delete them and recreate them by right-clicking on the terminal they should connect to and choosing Create -> Constant from the popup menu.
And what's with the I8 conversion on the channel numbers?
Unread 10-02-2014, 11:07
killer_rabbit3's Avatar
killer_rabbit3 killer_rabbit3 is offline
programming rabbit
AKA: Alexander Martinez
FRC #1038 (Lakota Robotics)
Rookie Year: 2012
killer_rabbit3 is an unknown quantity at this point
Re: Solenoid issues
Most likely your problem is caused by the coercion dots and hqving labview convert one data type to another. But i do know that the breakout board can cause soenoid connection problems if its not receiving the correct amount of power.
Unread 10-02-2014, 13:23
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
Rookie Year: 2013
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Re: Solenoid issues
Instead of Channel # it should say Solenoid #
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 10-02-2014, 22:11
FRC #4641
Re: Solenoid issues
Thank you for your help, I was able to add the constants and they work like angels now.
