Go to Post Word of advice:Don't eat a whole box of nutrigrain bars that are loaded with fiber in one sitting...Yeah.. Bad thing. - Elgin Clock [more]
Unread 02-10-2014, 06:09 PM
Zach S. Zach S. is offline
FRC #3307 (Luray Robodawgs)
Rookie Year: 2011
Zach S. will become famous soon enough
Double solenoid code
I've been trying to wrap my head around this code for two days now and I can't figure it out. I've got the declaration (DoubleSolenoid festo) and the port set ( festo(1, 2)) what is the code for teleop that gives me control of the solenoid, this is the only thing I can't get
Head of Computer Systems and Programming of Team 3307
Unread 02-10-2014, 09:43 PM
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Double solenoid code
http://wpilib.screenstepslive.com/s/...ders-solenoids should tell you what you need to know. Briefly, use the Set() method of the DoubleSolenoid class, passing it one of the constant values kOff, kForward, and kReverse.
Unread 02-11-2014, 12:36 PM
Rookie Year: 2011
My line of code for Set() looks like this
Code:
festo.Set(kForward);
festo is the call for our DoubleSolenoid. When i try to build the code I get the following errors:
Code:
C:/windriver/workspace/SimpleTemplate/MyRobot.cpp: In member function `virtual void RobotDemo::OperatorControl()':
C:/windriver/workspace/SimpleTemplate/MyRobot.cpp:58: error: `kForward' undeclared (first use this function)
C:/windriver/workspace/SimpleTemplate/MyRobot.cpp:58: error: (Each undeclared identifier is reported only once for each function it appears in.)
Any idea why the Set() I am using is not working?
Unread 02-11-2014, 12:42 PM
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
Because kForward is a member of the DoubleSolenoid class. Use DoubleSolenoid::kForward
Unread 02-11-2014, 01:30 PM
Rookie Year: 2011
Sorry, I am a bit new to C++ (recently switched from labview) where is it that I make the ::kForward, is it in the Teleop, or init?
Unread 02-11-2014, 01:47 PM
In the set line that you posted, replace kForward with the text I posted above.
Unread 02-11-2014, 01:48 PM
Rookie Year: 2011
Thanks, the code built correctly I will try this out on the bot today!
Unread 02-17-2014, 02:07 PM
Rookie Year: 2011
Okay, tested the program but I still have an issue.
The code seems to be working, I can see the lights on the FESTO changing as I hit the button on the joystick, however, it seems that the solenoid will not fire. Is this a wiring or more code problem? And how can we get this fixed?
Unread 02-17-2014, 02:25 PM
Software Architect
Is it a 12 volt or a 24 volt solenoid? Are you providing it with the voltage it requires?
Do you have enough pneumatic pressure supplied to it for the pilot valve to activate?
Unread 02-17-2014, 04:41 PM
Rookie Year: 2011
24 Volt, I have the wires running from the solenoid breakout board into the FESTO. And as for pressure we are building it up to 60 for testing, and nothing is firing.
Unread 02-17-2014, 09:52 PM
Software Architect
Just to be certain: Are you feeding the Solenoid Breakout's power input with 24 volts?
Unread 02-18-2014, 09:48 AM
Rookie Year: 2011
Yes, we have a 20 amp fuse on it, should we be using a 30 amp?
Unread 02-18-2014, 09:59 AM
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
Running it through a breaker would only give it 12 volts. 24 volts has to come from the power supply at the bottom of the PDB.
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
Unread 02-18-2014, 10:30 AM
Software Architect
Right.
The cRIO only uses the first two terminals of the four on the 24v output of the Power Distribution Board. Use the second two to feed the Solenoid Breakout.
(The black connectors show a NC on the third terminal, but the PDB itself provides 24v there.)
