Go to Post Without compromise, engineering would be boring. - Mike Betts [more]
Unread 10-02-2014, 20:09
antj antj is offline
FRC #4738
antj is an unknown quantity at this point
How do you program the signal light?
I want to know how to program the signaling light for tele-op and autonomous mode, etc. in labview please. Thank you.
Unread 10-02-2014, 20:58
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
Rookie Year: 2013
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Re: How do you program the signal light?
You don't. It is already written when you create a Crio Project.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 10-02-2014, 21:29
DonRotolo's Avatar
Back to humble
FRC #0832
Yes, just connect it as shown and it works. Like magic.
Unread 10-02-2014, 21:43
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
Rookie Year: 2013
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
Just make sure you hook it up properly. If you reverse the polarity all the Magic smoke comes out and no longer will work.
Student hooked it up backwards last year, expensive mistake.
Unread 11-02-2014, 23:42
tcjinaz tcjinaz is offline
Tim
FRC #3853
Rookie Year: 2011
tcjinaz has a spectacular aura abouttcjinaz has a spectacular aura about
Are you sure you were'nt top-heavy with 1's, where 0's would have kept the weight down?
Software Mentor
3853 Pridetronics[
Unread 12-02-2014, 19:50
FRC #4738
Ok thank you. Our team figured out that our light wasn't getting enough voltage.
