Go to Post *When putting grease on anything* "The bigger the glob the better the job." - TheMagicPenguin [more]
Unread 11-02-2014, 23:46
Michael Yeh Michael Yeh is offline
Lead Chief Delphi Lurker & CAD/Mech
FRC #4099
Team Role: Mechanical
Rookie Year: 2013
Michael Yeh is an unknown quantity at this point
Re: 2014 FRC's Biggest Loser
Our robot hit 110 lbs on a very old bathroom scale today, which is almost exactly what our CAD said. We plan to acquire a better scale, but we had some people with known weights "calibrate" that one. Our structure is pretty simple but is mostly heavy 2x1x.125" tubing and we're using all 6 CIMs, 4 miniCIMs, and a pair of AM 9015s on the PG-71 gearboxes (no, we don't plan to pop the breaker every match )
The tubing is mostly solid so we may try to make some sort of jig to swiss cheese our unbagged parts. Life would probably have been much easier if we used the thinner Vex tubing, but they were out of stock until the day we placed our order. We may also switch out the miniCIMs with banebots motors in versaplanetaries or CIMiles if we can afford it.
Unread 12-02-2014, 20:44
piersklein piersklein is offline
Rookie Year: 2014
piersklein is a jewel in the roughpiersklein is a jewel in the roughpiersklein is a jewel in the roughpiersklein is a jewel in the rough
Rookie team here and we WAY over built (the team takes durability way too firmly). We are at 110lbs and do not shoot. We are using 3 by 1.5 in double extrusion for arms which weigh in at 50 lbs. And do not have much to save weight in. On the plus side, we can *accidentally* be a battering ram.
Unread 17-02-2014, 15:09
Master Mac Master Mac is offline
FRC #1075
Master Mac is an unknown quantity at this point
And if we ever meet on the field I sure hope you are full of Gracious Professionalism, because this comment is not what first is about, and as a rookie team you will not go far with this type of comment. I wish if I was a robot inspector in your regional you never make it to the field if I had seen this post.
Unread 11-02-2014, 11:02
DELurker DELurker is offline
Former Engineering Mentor
AKA: William Lydick
no team (n/a)
Rookie Year: 2011
DELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant future
Originally Posted by droswell View Post
We learned a valuable lesson about being 2" under frame size and ALWAYS weight your bot _before_ showing up to a regional.
Our current weighing method is to take two students, weigh them on a pair of bathroom scales, then weigh them while they are both holding the robot. Subtract out the student weights and you get the answer +/- 1 lb. If you then rotate the robot 90 degrees and repeat, you could actually figure out the location of the center of gravity of the robot in the horizontal plane. I'm not a fan of turning the robot on its side to get the vertical axis of the CG...
With 1370 --
2012 Rutgers District Event Champions with 1676/56
2012 Lenape District Event Finalists with 2191/1691
2013 TCNJ District Event QuarterFinalists with 1143/4750, Gracious Professionalism Award
2013 Bridgewater-Raritan District Event Semi-Finalists with 4285/223
2013 MAR Championship Finalists (Backup) with 222/11/1403; Gracious Professionalism Award
Unread 11-02-2014, 14:14
Chadfrom308's Avatar
Chadfrom308 Chadfrom308 is offline
Slave to the bot
AKA: Chad Krause
FRC #0308 (The Monsters)
Team Role: Driver
Rookie Year: 2011
Chadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to beholdChadfrom308 is a splendid one to behold
Originally Posted by DELurker View Post
Hoping you mean Lexan/polycarbonate/Makrolon... Plexiglas is prone to shattering.
Yes, I couldn't think of the name for it!
Unread 11-02-2014, 10:46
BoilerMentor BoilerMentor is offline
FRC #1747
BoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond repute
Originally Posted by wilsonmw04 View Post
I would do this first.
I fail to see the significant benefit of 7lbs. vs. what 6 cims give you.
The drive train is geared for 6 CIMs. That is precisely the problem with removing them. It is also a surprisingly large amount of work to remove them as well. You can't get at them from the outside of the gearbox, so we'd probably have to remove our drive modules, remove the transmissions from those, split the transmission, remove the motors, then reassemble. Compared to most of the other items on the list it is much more difficult.
Also, it would hurt our strategy pretty severely and go completely against an important lesson the team learned last year regarding the value of defensive play.
Lastly, the robot should cross the field (calculated including wheel slip with all six cims) in 3.25 seconds. In the case we have to cycle by ourselves they will be fast cycles.
AKA: William Lydick
no team (n/a)
Rookie Year: 2011
Originally Posted by BoilerMentor View Post
With the current position HBR has found themselves in, I thought this might be a fun thing to look at.
Share your robot weight situation and describe your remedy.
On paper, with the battery, 6 lbs of bumpers, and without bolts or wires (we're not going to model them), we're at 102 lbs. Our method was lightweight parts, thin Lexan, and perforated PVC panels. That, and an intense desire to break the three-year trend of being within 0.5 lbs of the upper weight limit at weigh-in ... since our shop scale broke.
With 1370 --
Unread 11-02-2014, 11:12
TheFrozenSlink's Avatar
TheFrozenSlink TheFrozenSlink is offline
AKA: Darshan 'So-lanky'
FRC #0171 (Cheese Curd Herd)
Rookie Year: 2011
TheFrozenSlink is on a distinguished road
Our robot weighs 72.75 pounds. If anyone would like to send us weight go right ahead
Team 3352: 2011-2014
Team 171: 2014-[forever, or until I graduate ]
Unread 11-02-2014, 11:27
FRC #1747
You guys are making me feel self conscious about our robot weight...
Unread 11-02-2014, 14:55
MechEng83's Avatar
MechEng83 MechEng83 is offline
Lead Mentor/Engineer
AKA: Mr. Cool
FRC #1741 (Red Alert)
Team Role: Coach
Rookie Year: 2011
MechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond repute
we weighed systems last night and are coming up with 120 lbs... We're still missing some important items like the sponsor panel, which is also the entire front of our robot.
Luckily, we designed in some weight savings opportunities should the need arise. looks like we'll be diving into that.
On a completely unrelated note , anyone know where we can get a 26" long 1/2" keyed aluminum shaft? The longest I can find right now is 24"
2016 INWLA GP| INWCH Entrepreneurship | INPMH DCA | INCMP Team Spirit | CAGE Match Winner (w/ 1747 &868), Finalist (1471 w/ 1529 & 1018), Best Fans
2015 ININD Judges Award, Proud "Phyxed Red Card" alliance partners of 1529 & 1720 | INWLA EI | INCMP GP
2014 Boilermaker Creativity | Chesapeake Finalist, Safety, GP, Entrepreneurship | IN State Championship Winner (w/ 868 & 1018) | CAGE Match Winner (w/ 1024, 5402 & 1646)
2013 Boilermaker RCA, Innovation in Controls, Finalist | Crossroads Entrepreneurship | Newton Semi-finalist
2012 Boilermaker Entrepreneurship | Queen City EI | Curie Semi-finalist
2011 Boilermaker RCA, Entrepreneurship
Red Alert Robotics
Unread 11-02-2014, 15:47
JamesCH95's Avatar
JamesCH95 JamesCH95 is online now
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
JamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond repute
We weighed in at 110lbs fully loaded.
I would be tempted to stick two chunks of shaft together with a ferrule insert to couple them, using a key to ensure that the two shafts' keyways lined up.
Like this:
Theory is a nice place, I'd like to go there one day, I hear everything works there.
Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot.
Unread 11-02-2014, 16:23
nathannfm's Avatar
nathannfm nathannfm is offline
AKA: Nathan
FRC #3940
nathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant future
Like this:
I am not quite sure what this is, but it got me thinking, you could get 2 pieces of shaft, tap the ends of both and connect them with a piece of threaded rod. Same concept I think.
As for hex shaft, I have found that the Vex hex shaft is extremely high quality and precision, you may want to look into that.
[2016-20??]: Mentor: FRC Team 3940"CyberTooth"
[2013-2016]: Mentor: FRC Team 365 "MOE"
[2012-2013]: Mentor: FRC Team 3929 "Atomic Dragons"
[2011-2012]: Mentor: FRC Team 365 "MOE"
[2008-2011]: Student: FRC Team 365 "MOE"
[2007-2008]: Student: FTC Team 365 "MOE"
[2005-2007]: Student: FLL Team "The MOEstangs"
Unread 11-02-2014, 16:26
Oblarg Oblarg is offline
AKA: Eli Barnett
FRC #0449 (The Blair Robot Project)
Oblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond repute
Unfortunately, I have found that the probability of a vex hex bearing fitting on a vex hex shaft without issue is about 50%, though I might just have really rotten luck.
"Mmmmm, chain grease and aluminum shavings..."
"The breakfast of champions!"
Member, FRC Team 449: 2007-2010
Drive Mechanics Lead, FRC Team 449: 2009-2010
Alumnus/Technical Mentor, FRC Team 449: 2010-Present
Lead Technical Mentor, FRC Team 4464: 2012-2015
Technical Mentor, FRC Team 5830: 2015-2016
Unread 11-02-2014, 16:43
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
That's a technique for sticking carbon fiber tubes together to make longer carbon fiber tubes.
It is the same concept, but there are two reasons to not use a threaded rod. First, the keyways would have a negligibly small chance of lining up with each other. Maybe a problem, maybe not. Second, you would have to make darn sure that threading never came apart, or even loosened a little bit. If it did, you'd have threading in bending, and that is a very bad time.
  #15   Spotlight this post!
Unread 11-02-2014, 16:54
magnets's Avatar
magnets magnets is offline
Rookie Year: 2012
magnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond reputemagnets has a reputation beyond repute
First try deburring the edges. Then just sand down the hex shaft. You loose the fancy paint, but it fits!
As for the long shaft source, you could go with McMaster, which sells some .500 aluminum rod with the "ground and polished" finish. This will be the exact diameter, but doesn't have the keyway cut into it. You could then cut your own keyway, use a roll pin, or make some flat parts on the shaft, and use a set screw.
