Go to Post Sorry, during my fluid mechanics lectures on drag I must have been designing a gearbox in my mind. FRC season will do that. - sanddrag [more]
View Poll Results: So how do you pick up?
Horizontal Rolly Grabber 71 55.04%
Vertical Rolly Grabbers 25 19.38%
Clamp/Pincher 13 10.08%
Other 20 15.50%
Voters: 129. You may not vote on this poll
Unread 12-02-2014, 01:31
Tyler_Kaplan's Avatar
Tyler_Kaplan Tyler_Kaplan is offline
Mentor
FRC #1678 (The Citrus Circuits)
Rookie Year: 2011
Tyler_Kaplan is a glorious beacon of lightTyler_Kaplan is a glorious beacon of lightTyler_Kaplan is a glorious beacon of lightTyler_Kaplan is a glorious beacon of lightTyler_Kaplan is a glorious beacon of lightTyler_Kaplan is a glorious beacon of light
How do you grab the ball?
I hope everyone has had a good build so far, and I wish all of the teams good luck as we finish out with the last week. But as we start to focus a lot of energy on driver training, as coach I'd like to get a better idea of how most robots will be grabbing/picking up the ball. I've seen a lot of teams who use a horizontal bar with wheels on top of it, and the only problem I see with this is that it will be a challenge to corral the ball if it is bouncing a lot. So what kind of mechanism are your teams using? Thanks and good luck!
Unread 12-02-2014, 02:09
RohitD's Avatar
RohitD RohitD is offline
Sleep? What is this term?
FRC #2489 (Insomniacs)
Team Role: Leadership
Rookie Year: 2012
RohitD is an unknown quantity at this point
Re: How do you grab the ball?
We're currently running the above mentioned horizontal bar with wheels. Regarding the bouncing, we tested that along with the amount of time it took a ball to stop bouncing and effectively start rolling. We weren't having any huge issues with intake.
2013 Sacramento Regional Winners—Thank you teams 701 and 3189! #greenalliance
Unread 12-02-2014, 09:12
Solive Solive is offline
FRC #1421 (Chaos)
Rookie Year: 1999
Solive is an unknown quantity at this point
We built a prototype like you described. It worked pretty well. We also built "El Toro". After testing both we prefer El Toro but both will work. Try experimenting with different wheels. Softer rubber will be better.
Unread 12-02-2014, 09:17
Oblarg Oblarg is offline
AKA: Eli Barnett
FRC #0449 (The Blair Robot Project)
Oblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond repute
Overhead PVC roller covered with TheraWrap, driven by a RS550 on a 26:1 gearbox.
Works like a charm.
"Mmmmm, chain grease and aluminum shavings..."
"The breakfast of champions!"
Member, FRC Team 449: 2007-2010
Drive Mechanics Lead, FRC Team 449: 2009-2010
Alumnus/Technical Mentor, FRC Team 449: 2010-Present
Lead Technical Mentor, FRC Team 4464: 2012-2015
Technical Mentor, FRC Team 5830: 2015-2016
Unread 12-02-2014, 10:06
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
Rookie Year: 2013
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
With our hands......
Unread 12-02-2014, 13:27
Dr.Gusta's Avatar
Dr.Gusta Dr.Gusta is offline
FRC #5107 (The Neurotoxins)
Team Role: CAD
Rookie Year: 2014
Dr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of lightDr.Gusta is a glorious beacon of light
We use a 1114 2008 style claw.
Unread 14-02-2014, 19:20
'lil robo-girl 'lil robo-girl is offline
None #3218
'lil robo-girl is an unknown quantity at this point
We have what boils down to a handheld vacuum cleaner attached to a huge suction cup on a metal arm. We added a stronger motor to the vacuum so that it can pick up the ball, which it takes a second or so to do. The biggest problem is that the ball has to be pretty exactly lined up for the seal to form, but there's enough flex room for it to mostly line itself up.
Unread 14-02-2014, 21:45
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
We have a horizontal roller intake. While it is horizontal, it isn't like any intake debuted on a robot (Ri3D or otherwise) thus far.
GitHub
