Go to Post FIRST is aimed at those girls on your team. They don't know anything about mechanics, or electricity, or programming, or machining. They have no interest in it, either. They're perfect candidates for FIRST. - Madison [more]
Unread 12-02-2014, 12:08
Zaque Zaque is offline
FF: Bobo Brigade
AKA: Zachary H.
FRC #3352 (Flaming Monkeys)
Rookie Year: 2013
Zaque has a spectacular aura aboutZaque has a spectacular aura aboutZaque has a spectacular aura about
Compressor code not working
Hi all,
Our compressor does not start using the premade compressor class.
Things we have done:
-Changed digital sidecars
-Tested the relay slot with a different spike powering a motor
-Confirmed all three lights are on on the digital sidecar without the cable to the crio plugged in
-Tried a different relay slot
-Turned on the spike with a button instead of compressor.start()
-confirmed the digital io slot worked
Things we didn't do:
-check the error window
-change digital modules
Any ideas? And if we can't get the compressor class to work, can I write my own control loop using the pressure switch?
Thanks,
Zaque
Zaque (Zach) H.
President
Programming/Electrical Lead
