Go to Post Thank you to all of the mentors, You ARE changing the future. - chellyzee93 [more]
Unread 12-02-2014, 14:57
philso philso is offline
Mentor
FRC #2587
Rookie Year: 2011
philso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond repute
Another electrical inspection question
Will the Inspectors require that all wire have the size visible (printed) on the wire?
I noticed last night that some of the wiring to the motor controllers was done using 12AWG wire that did not have the wire size printed on it. The reel had the wire size on it and the conductor size looked right when compared to wire of a know size.
Thanks.
Unread 12-02-2014, 15:16
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
Team Role: Teacher
Rookie Year: 2011
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Re: Another electrical inspection question
Usually not in my experience.
What they do is look at the wires and ask a student to tell them what gauge it is. If the student can answer, and use the correct number, and it looks like the appropriate size, they're OK.
Again, that has been my experience at 4 regional competitions. Your results may vary.
Unread 12-02-2014, 15:17
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Rookie Year: 1999
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
In the past when I've done robot inspection, we have a board with bits of wire stapled to it as reference for sizing.
Unread 12-02-2014, 15:19
Taylor Hawkins Taylor Hawkins is offline
2386 BCHS Trojans
FRC #2386 (Trojans)
Rookie Year: 2010
Taylor Hawkins is an unknown quantity at this point
Thanks.
We have never had a problem with that however if the inspector feels that the wire diameter is too small they can have you change that wire to something of the correct size.
What are you running with that wire? Are you right on the cusp of the amperage limit for that guage of wire or do you oversize all your wire?
Unread 12-02-2014, 15:37
Andy A. Andy A. is offline
Getting old
FRC #0095
Team Role: Coach
Andy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond repute
While labeling requirements are not specifically called out in either the rules or inspection checklist, an inspector is tasked with verifying that wiring is appropriately sized. The most foolproof way to demonstrate that a wire is correctly sized is to have it labeled as such by the manufacturer. There is enough variation in insulation thickness that you really can't/shouldn't rely on outward appearance. An experienced inspector can probably size wire that way, and they are given examples as part of the training, but the burden of proof is ultimately upon the team should any questions arise.
Some wire may not have a size listed on it from the manufacturer*. If that's the case for your robot, I'd strongly recommend that you bring the spool that wire came off of, which should have the size printed on it, with you to competition. An inspector can compare the wire on the spool with the wire on the 'bot and that'll satisfy 9 out of 10 inspector concerns.
Andy A.
*Incidentally I'm not sure if the lack of labeling signifies a lack of some certification or class rating. I'd be curious to hear from any anyone who knows the ins and outs of wire sizing and classifications about that.
Unread 12-02-2014, 15:48
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Electrical/Programming Mentor
FRC #2177 (The Robettes)
The burden of proof is always on the team. That's why we ask teams to bring data sheets for some stuff (like pneumatic components) - they have to prove the specs of whatever we're looking at meeting the rules.
When looking at wire, I can usually tell if a particular wire is the correct gauge. Sometimes, though, I'm not sure and I look for labeling on the wire itself. If the labeling isn't there, then the team will need to provide proof that the wire is the correct gauge - for this, the spool (with some wire still on it) with correct labels would probably suffice. If nothing else, I'll grab a set of wire strippers and strip a short (<1/2") section on a spare piece of wire to make sure it is the correct gauge.
I also always ask the students what gauge the wire is. It's something they should already know and be able to answer, and when they can't it's a teaching moment.
2007 - Present: Mentor, 2177 The Robettes
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016; Galileo 2016; Iowa 2017
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
Unread 12-02-2014, 16:24
Mentor
FRC #2587
Rookie Year: 2011
The wire they used comes as a red-black pair with an overall jacket. The wire size is printed on the jacket. For our application (to and from motor controllers), we are discarding the jacket.
We can always bring a piece with the jacket that has the printing.
Unread 12-02-2014, 16:29
Mentor
FRC #2587
Rookie Year: 2011
Unread 12-02-2014, 19:54
DonRotolo's Avatar
Back to humble
FRC #0832
Do that, with the wires still in the outer jacket, so the inspector can see it.
