Go to Post This thread has officially jumped the shark! the old guy shark :) - IndySam [more]
Unread 02-12-2014, 03:20 PM
JohnGilb JohnGilb is offline
Programming Mentor, Drive Mentor
FRC #0488
JohnGilb has a spectacular aura aboutJohnGilb has a spectacular aura aboutJohnGilb has a spectacular aura about
How to profile?
Are there best practices around profiling java code on the cRIO?
In the past when programming in LabVIEW we took advantage of the built-in profiler to analyze the performance of our code.
Is there something similar that can be done with Java/NetBeans?
Unread 02-12-2014, 03:22 PM
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is offline
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
notmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond repute
Re: How to profile?
You can see the cpu usage on the driver station while running, other than that I don't know of anything.
Unread 02-12-2014, 03:48 PM
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: How to profile?
...profiling java code on the cRIO...
You can instrument the code and write the results in a large RAM array.
Then examine the array offline.
