Go to Post I think this thread just won "ChiefDelphi is terrible Bingo". - Karthik [more]
Unread 12-02-2014, 15:26
Alexplayer777's Avatar
Alexplayer777 Alexplayer777 is offline
None #3044
Alexplayer777 is an unknown quantity at this point
Netbeans freezes with Windows 8.1
Hi.
So one of the computers with windows 8.1 on our team freezes at conneting to ftp 10.xx.yy.2 while deploying code wiht netbeans, java.
Any ideas on how to solve it?
Thanks!
Unread 12-02-2014, 17:38
irvingc irvingc is offline
FRC #0948 (Newport Robotics Group)
Team Role: Leadership
Rookie Year: 2011
irvingc is on a distinguished road
Re: Netbeans freezes with Windows 8.1
I don't know of any inherent compatibility issues with NetBeans and Windows 8.1 (as in, I run NetBeans on Windows 8.1 without issue). Can you be more specific about the nature of the freezing? Does only NetBeans freeze, or the whole system crashes?
Unread 12-02-2014, 18:08
Pratik Kunapuli's Avatar
Pratik Kunapuli Pratik Kunapuli is offline
Probably browning-out on Astro-Turf
FRC #1648 (G3 Robotics)(EWCP)
Rookie Year: 2012
Pratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to all
Are you sure the output isn't freezing? We've been stuck at that point before and needed to change our network settings.
Official Driving Record: 101-59-0
2012-2015 Student 341 Miss Daisy
2015-Current Mentor 1648 G3 Robotics
Unread 12-02-2014, 19:42
None #3044
I believe it is the output window that is freezing. Netbeans usually connects normally and uploads, but occasionally, the output window stops at connecting to ftp @10.30.44.2, and will not go any further, and we cannot do any further uploads until we restart netbeans. i have tried reinstalling the plugins, and this will not fix it. if you have any ideas, it would be very useful as this is a very irritating bug.
Unread 12-02-2014, 20:42
Rookie Year: 2011
I know that on some of our machines, Windows Firewall blocks the FTP connection by default. You can try temporarily disabling it in the Control Panel when working with robot code. Also, the next time this happens, you should try pinging the cRIO and/or manually opening an FTP session from the command line to test network connectivity.
Unread 12-02-2014, 21:11
yash101 yash101 is offline
Curiosity | I have too much of it!
AKA: null
Rookie Year: 2012
yash101 is an unknown quantity at this point
Try reinstalling Netbeans! I run 8.1 (but hexboot ubuntu and windows 7). I've never had this problem! I actually think everything runs better in 8.1 than in 7!
