Go to Post We're not disappointed if we don't achieve excellence, so long as we did everything we could in our pursuit of it. - JVN [more]
Unread 12-02-2014, 16:49
kamikazejoshua kamikazejoshua is offline
FRC #3793
kamikazejoshua is an unknown quantity at this point
losing connection to cRIO over wifi
We are having problems connecting to the radio through wifi. It seems that it is more of a laptop problem because when looking on the taskbar that shows the connections, it rotates between connected and connecting. When looking at the driver station, the robot code and the connection continuously blinks green and red. The only time that it seems to work is when we restart. That lasts for about a minute. We have ran the bridge configuration and our ip address is 10.37.93.9 and our subnet is 255.255.255.0.We do not have a problem using the crossover cable between the laptop and the cRIO. We are not using our classmate for this. But, we are in the process of updating the classmate to see if the laptop is the problem. We have an outdated driver station currently on the classmate but on the taskbar it is showing that we have a continuous connection. Any ideas on what to check for or troubleshooting would be greatly appreciated.
Thanks
