[Help] Compressor Problem (Java)
So we want our compressor to start immediately once the robot has turned on and this is a simple java code we're experimenting with.
We've imported this class : Compressor compressor = new Compressor(1, 1); And this is our current code: public void robotInit() { compressor.start(); } public void disabled() { compressor.stop(); } Once I deploy this code I get an error. ([cRIO] Robot Drive... Output not updated often enough.) In addition, I've confirmed that the compressor code is causing this problem because I commented out the compressor code and the cRIO accepted the code, but when I tried to deploy the code with the compressor I get that error. I'm not sure if our team's compressor code is correct or not so please help us out. |
