Go to Post While in the Navy, we had an apparent leak in one of our systems and it took me 7 months to track it down. Just because you haven't found it, doesn't mean it doesn't exist. - TubaMorg [more]
Unread 13-02-2014, 17:24
LATech LATech is offline
FRC #4955
LATech is an unknown quantity at this point
talon sr mounting hole size???
we need to attach 40mm fans to our talon sr motor controllers and we need to buy the bolts to attach them; unfortunately having searched we cannot find the the size of the bolts required for the talons...anybody know?
Unread 13-02-2014, 17:27
potatoshane potatoshane is offline
FRC #2813
potatoshane will become famous soon enough
Re: talon sr mounting hole size???
Might be #6-32 Not absolutely sure though
EDIT:
Just look at the talon manual, it is indded 6-32
http://www.crosstheroadelectronics.c...Manual_1_1.pdf
Unread 13-02-2014, 17:32
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
From the manual:
8) Optional Fan
The Talons heat sink has two bosses tapped to 6-32. These bosses may be used to install an optional 40 mm x 40 mm fan or to mount the Talon.
I'm right 90% of the time, so why worry about the other 3%?
