Go to Post How well does peanut butter transmit heat? - Lil' Lavery [more]
Unread 14-02-2014, 13:27
Nunners Nunners is offline
FRC #4155
Nunners is an unknown quantity at this point
Exclamation Ball Shifters - weird shifting behavior
Team 4155 is using ball shifters as a ratcheting/neutral gear mechanism as a part of our catapult system like many other teams on CD are doing. However, the piston controlling which set of gears is engaged is behaving in a way I wasn't expecting.
Basically, whenever our motor is activated and begins to wind our winch, the shifter unexpectedly shifts to the neutral gear almost immediately. We noticed that this problem can be delayed by providing more PSI to the piston itself (much more than 30 psi).
If you work the gearbox with your hand, it seems that rotating the axle on which the winch is mounted is somehow "pulling" the piston into the gearbox and switching into our neutral gear. You have to physically hold the shifter to keep this from happening.
Is this normal behavior for the ball shifters? I do not have any previous experience with them and was wondering if someone could provide some information in order to help us troubleshoot.
Unread 14-02-2014, 13:49
T^2 T^2 is offline
FRC #5499
Rookie Year: 2011
T^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond repute
Re: Ball Shifters - weird shifting behavior
You need at least 40psi; 60 is best.
Unread 14-02-2014, 13:55
FRC #4155
So it is normal that rotation of the axle causes the shifter to move? We just need more PSI on the cylinder itself to keep it stationary?
Unread 14-02-2014, 14:01
slao slao is offline
AKA: Steven Lao
FRC #3161 (Tronic Titans)
slao has much to be proud ofslao has much to be proud ofslao has much to be proud ofslao has much to be proud ofslao has much to be proud ofslao has much to be proud ofslao has much to be proud ofslao has much to be proud of
Did you rearrange the gears on the ballshifter mechanism, or is it still in the stock configuration? We had a similar symptom when we reassembled the ballshifter and mixed up the position of the gears and washers.
Unread 14-02-2014, 14:05
FRC #4155
We've replaced a gear with a ratcheting wrench. During our troubleshooting last night, we noticed that we are actually missing a spacer that fits on the outside of the upper gears. We replaced it with a fabricated part last night but didn't have time to test it.
I wonder if this might be the cause of our problems. I don't know why it would cause the shifter to move, though.
Unread 14-02-2014, 14:17
AKA: Steven Lao
Sounds similar to what we did. I believe that the spacer helps axially line up the grooves in the gear with the balls. Because it's not lined up without that spacer the balls aren't sitting inside the grooves fully, and so applying some torque will push the balls back inside and move the shifter also.
Unread 14-02-2014, 14:21
Taylor Hawkins Taylor Hawkins is offline
2386 BCHS Trojans
FRC #2386 (Trojans)
Rookie Year: 2010
Taylor Hawkins is an unknown quantity at this point
Take a look at this thread
http://www.chiefdelphi.com/forums/sh...hreadid=126444
