Go to Post Everyone better enjoy the broadcast, Dave had to cancel a shuttle launch to make it happen :D - The Lucas [more]
Unread 14-02-2014, 14:33
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: Compressor gets hot and blows line
Originally Posted by matthewdenny View Post
So when we enable the robot the compressor kicks on, the pressure builds in our high pressure tanks, gets to 65 psi, holds there for ~20 seconds,
You're missing a few important pieces of information. How long is the compressor on when it's building pressure in your high pressure tanks? What gets to 65PSI, low pressure gauge or high pressure gauge? How much air storage do you have on the high pressure side?
I suspect you've mis-plumbed something or have a leak somewhere, causing the compressor to be on much longer then expected.
Unread 14-02-2014, 14:34
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Mark I think has the solution. I did not consider the regulator in backward. It is designed to vent to atmosphere any excess pressure on the output port.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 14-02-2014, 14:40
matthewdenny's Avatar
matthewdenny matthewdenny is offline
FRC #6054 (Dukes)
Rookie Year: 2012
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
The high pressure side gets to 65 psi.
The compressor is on a minute or so, and gets to 65 psi, stays there, and half a min later or so blows the line.
~120 in^3 of air stored on te high side. No tanks after the main regulator.
Unread 14-02-2014, 16:01
FRC #6054 (Dukes)
Rookie Year: 2012
It turns out that the main regulator was tuned backwards. I'd like to blame the freshman that put it in, but I may have told him to so it that way in reflection. Chalk it up to last minute oversight.
Unread 14-02-2014, 16:05
FRC #6054 (Dukes)
Rookie Year: 2012
Al, I don't think I have posted in the lab view forum. We did have a java issue with motors recently that was resolved by calibrating the talons.
Unread 14-02-2014, 22:12
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
you might want to have fewer things cantilevered off of the compressor exit port. The material on the compressor is cast, and can crack at the seam of the casting. It looks like you have several heavy components attached.
We usually just have the fitting out of the compressor, the relief valve, and then a tube connector and everything else is mounted to a mounting board.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 15-02-2014, 14:56
PAR_WIG1350's Avatar
PAR_WIG1350 PAR_WIG1350 is offline
AKA: Alan Wells
FRC #1350 (Rambots)
PAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond repute
Alternatively, you could pass the fittings through panels to support them.
Unread 16-02-2014, 08:24
Unsung FIRST Hero
Rookie Year: 1996
Matthew,
So everything is OK now? When the line blew after only a minute, had the compressor been running for a long time before that? I am asking because one minute is much less than I would consider for the output temp to be so high. For all teams, this little compressor has a duty cycle spec. It really only expects to be run for a short time with a long off time in between so that it can cool down.
Al
WB9UVJ
www.wildstang.org
Unread 16-02-2014, 09:22
JamesCH95's Avatar
JamesCH95 JamesCH95 is offline
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
JamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond repute
While I do not disagree with you in principle, in practice we have run several robots like this without any failures.
Theory is a nice place, I'd like to go there one day, I hear everything works there.
Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot.
Unread 16-02-2014, 15:33
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
We had a similar problem to this one with our 2011 robot where the tubing would overheat and fail. We found this only occurred during demos following that competition season (it never actually happened at a competition), but nonetheless it got to be quite annoying to have to put a new piece of tubing on every few minutes.
Eventually we mounted one of the kit computer fans so it blew across the compressor, and the change in temperature was drastic.
We did tests and generated a chart based on the results:
https://docs.google.com/spreadsheet/ccc?key=0AqQx991m_YKGdEc3OV9NbG10YmluNjM2UFRhYV9Gb lE&usp=sharing
Long story short, if you can use a fan to cool your compressor, do it.
Unread 15-10-2014, 09:17
MechEng83's Avatar
MechEng83 MechEng83 is offline
Lead Mentor/Engineer
AKA: Mr. Cool
FRC #1741 (Red Alert)
Team Role: Coach
Rookie Year: 2011
MechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond repute
We had an interesting related failure last night while we were practicing for the upcoming CAGE Match off-season event.
The students were practicing a maneuver where the intake comes in and out, which means air was constantly being used for 15+ minutes. As I was shouting across the field for them to let the robot rest and have the compressor cool off, I hear a loud pop and the sound of uncapped compressor running. Turns out, the elbow fitting we use to come out of the t-fitting attached to the compressor failed, blowing off the ferrule assembly the tubing plugs into. The compressor was too hot to touch and I suspect the plastic on the 90 degree elbow got warm enough that the metal bit was able to slip past its molded grip.
It was a good reminder for my students why safety glasses are important while working near the robot, and that the Viair compressors shouldn't be run continuously. Because of space constraints, we can't really put a fan on the compressor the way it's mounted right now, but it's definitely something the students will remember next year (if we have pneumatics)
ID:	17391  Click image for larger version
2016 INWLA GP| INWCH Entrepreneurship | INPMH DCA | INCMP Team Spirit | CAGE Match Winner (w/ 1747 &868), Finalist (1471 w/ 1529 & 1018), Best Fans
2015 ININD Judges Award, Proud "Phyxed Red Card" alliance partners of 1529 & 1720 | INWLA EI | INCMP GP
2014 Boilermaker Creativity | Chesapeake Finalist, Safety, GP, Entrepreneurship | IN State Championship Winner (w/ 868 & 1018) | CAGE Match Winner (w/ 1024, 5402 & 1646)
2013 Boilermaker RCA, Innovation in Controls, Finalist | Crossroads Entrepreneurship | Newton Semi-finalist
2012 Boilermaker Entrepreneurship | Queen City EI | Curie Semi-finalist
2011 Boilermaker RCA, Entrepreneurship
Red Alert Robotics
Unread 15-10-2014, 09:20
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is offline
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
notmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond reputenotmattlythgoe has a reputation beyond repute
We found that even air blowing across the compressor works wonders. Almost everything on our robot this year was run by pneumatics so our compressor did a lot of work. Even after running through several batteries from practicing our compressor never got hot to the touch.
