Go to Post And who is to say what is the mean? Do I mean the mean? Or even the average? Or am I just being mean (or average, which could be my mean)? - dlavery [more]
Unread 14-02-2014, 15:12
Asymons Asymons is offline
FRC #4716 (Purple Raiders)
Team Role: Driver
Rookie Year: 2013
Asymons is an unknown quantity at this point
Viktor Speed Controllers and CIM Motors
Hi,
We were having a problem where 2/4 CIM motors on our robot would decelerate after we would stop moving the joystick instead of immediately stopping like the other 2 CIM motors. We've checked the gears twice, counted them, and resolved that it may be the speed controller. The two working ones are Viktor 884 Speed Controllers and the 2 others that aren't working are 883 and 884. We were thinking it may be that they aren't all the same speed controller.
Thanks for the help .
Unread 14-02-2014, 15:15
Bob Steele's Avatar
Bob Steele Bob Steele is offline
Professional Steamacrit Hunter
AKA: Bob Steele
FRC #1983 (Skunk Works Robotics)
Team Role: Coach
Bob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond repute
Re: Viktor Speed Controllers and CIM Motors
You need to set all of the victors to brake...
It is a jumper on the speed controller.
By the way the 883 is not a legal speed controller...for your competition robot
Hope this helps
Raisbeck Aviation High School TEAM 1983 - Seattle, Washington
Las Vegas 07 WINNER w/ 1425/254...Seattle 08 WINNER w/ 2046/949.. Oregon 09 WINNER w/1318/2635..SEA 10 RCA ..Spokane 12 WINNER w/2122/4082 and RCA...Central Wa 13 WINNER w/1425/753..Seattle 13 WINNER w/948/492 & RCA ..Spokane 13 WINNER w/2471/4125.. Spokane 14 - DCA --Auburn 14 - WINNER w/1318/4960..District CMP 14 WINNER w/1318/2907, District CMA.. CMP 14 Newton Finalist w 971/341/3147 ... Auburn Mountainview 15 WINNER w/1318/3049 - Mt Vernon 15 WINNER w/1318/4654 - Philomath 15 WINNER w/955/847 -District CMP 15 WINNER w/955/2930 & District CMA -CMP Newton -Industrial Design Award
Unread 14-02-2014, 15:31
Team Role: Driver
Rookie Year: 2013
Thanks for the reply back. We switched out the 883, kept everything 884. We tried it out again. When we move backwards it stops immediately. When we move forwards it doesn't stop immediately. The code that we're using for the drive train is:
myRobot.ArcadeDrive(stickD); // drive with arcade style (use right stick)
Wait(0.005); // wait for a motor update time
Unread 14-02-2014, 15:53
Bob Steele's Avatar
AKA: Bob Steele
Team Role: Coach
Are all of the jumpers on all of the speed controllers set to brake?
Here is a link to the manual for the 888 (almost the same as the 884) it shows the brake/coast jumper position
http://content.vexrobotics.com/vexpr...l_20130118.pdf
see if they are set to coast or to brake...
You also need to calibrate your speed controllers (individually) The instructions for doing that are in the pdf above.
good luck
Unread 14-02-2014, 16:02
Team Role: Driver
Rookie Year: 2013
Thanks we'll try it out tomorrow, we didn't realize that was apart of a speed controller haha.
Unread 14-02-2014, 16:05
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
Im not a software expert, but I dont think you want the Wait() statement. The ArcadeDrive should be in teleopPeriodic which runs when you get joystick updates (20ms).
But that is not this problem. Check your break/coast jumpers as already suggested. Calibrate the Victors - are they solid yellow (indicates commanded to zero velocity) when they are coasting?
Unread 14-02-2014, 16:38
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
it depends on whether they are using SimpleRobot or IterativeRobot. If SimpleRobot, then a wait is required. If IterativeRobot, no wait should be used.
