Go to Post As part of this test phase, I would expect to see Aidan sleeping on the job for most of the upcoming season. :) - dlavery [more]
Unread 14-02-2014, 22:32
cdromeoandjoule cdromeoandjoule is offline
FRC #0253
cdromeoandjoule is an unknown quantity at this point
Can't run program?
Hiiii
I'm running some programs in Java on Netbeans to control the electronics board, and everything was going well until I tried to switch the main program and then switch back. I also accidentally clicked "Clean and Build", then I exited in the middle of it because I meant to click "Run as main program"
The error message I got says:
[cRIO] GCs: 1 full, 0 partial
[cRIO] ** VM stopped: exit code = 1 **
[cRIO] task 0xcea978 (SquawkRobotTask) deleted: errno=0 (0) status=1 (0x1)
And I was wondering how I could fix it so it could run again?
Thanks!!
