Go to Post No caffine for you! - Koko Ed [more]
Unread 15-02-2014, 09:01
Dackarobot Dackarobot is offline
FRC #2905
Dackarobot is an unknown quantity at this point
Turning a motor for a specified time (timer)
Hello,
we want to turn one of out motors for a specified amount of time everytime a button on the joystick is pressed. Which structure should we use? Can we use it directly on Teleop.vi?
Unread 15-02-2014, 09:15
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Turning a motor for a specified time (timer)
It's easiest to do it in Periodic Tasks like this:
You must use different code in Teleop, because loops should not be used there.
Essentially, you would take the current time, add your delay to it whenever the button is pressed, then separately check to see if the time less than your target and set the motor speed accordingly.
