Go to Post I also would not recommend shipping the gerbils with the robot. - Stuart [more]
Unread 02-15-2014, 07:16 PM
EmmettNervend EmmettNervend is offline
FRC #4296 (Trident Robotics)
Rookie Year: 2012
EmmettNervend is an unknown quantity at this point
Getting data from RoboRealm into C++
We're trying to create a targeting program for this year's competition using RoboRealm. We have been able to create a .robo that accurately reads distance from a hot goal. It includes the Network_Tables layer and we have told it to send our value for distance to the SmartDashboard according to this guide:
http://www.roborealm.com/help/Network_Tables.php
We didn't have any success with this tutorial or any of the others we found.
Have any of you been able to get values from RoboRealm into C++ code? Are there any good tutorials out there?
Unread 02-16-2014, 07:31 PM
bvisness's Avatar
bvisness bvisness is offline
Programming Mentor, Former Driver
FRC #2175 (The Fighting Calculators)
Rookie Year: 2010
bvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of light
Re: Getting data from RoboRealm into C++
As soon as RoboRealm starts putting values on the Network Tables, then you should see them on the SmartDashboard. Once it's displayed on the SmartDashboard, all you have to do is use this line of code:
Code:
SmartDashboard::GetNumber("YOUR_VARIABLE_NAME");
So in your case, it would probably be something like:
Code:
double distance = SmartDashboard::GetNumber("DISTANCE");
Unread 02-23-2014, 08:56 AM
BradAMiller BradAMiller is online now
AKA: Brad
#0190 ( Gompei and the Herd)
BradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant futureBradAMiller has a brilliant future
This is for java but should be easy to translate. http://wpilib.screenstepslive.com/s/...with-roborealm
Brad Miller
Robotics Resource Center
Worcester Polytechnic Institute
