Encoders to PWM
How do we wire these encoders to our robot? We are using a digital sidecar and all the PWM outputs are taken.
http://www.andymark.com/product-p/am-0791.htm |
Re: Encoders to PWM
They connect to Digital Inputs (DIO) on the sidecar.
By pin number: 1. +5 VDC power -> 5v power Last edited by Mark McLeod : 16-02-2014 at 09:02. |
Re: Encoders to PWM
Encoders actually get plugged into the digital i/o section of the digital sidecar. You should hook up the leads of the encoder to 2 3-pin connectors with one having A and ground and the other having B and power (or vice versa - the important thing is that A and B are on separate connectors). Put A and B on the signal pins and power and ground on the appropriate pins.
