Go to Post I would have bought a bigger box of popcorn and sat up higher in the stands. In the middle. - JaneYoung [more]
Unread 16-02-2014, 02:34
Thad House Thad House is offline
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Rookie Year: 2010
Thad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond repute
Sidecar Brownout causing motors to move
We were testing our drive today with a dead battery accidentally, and whenever we would reverse the drive we could see the sidecar was browning out. We know not to do this, but when it happened all the Talons would turn on backwards for a split second. It this the expected behavior for a sidecar brownout, or do we have a bad sidecar?
All statements made are my own and not the feelings of any of my affiliated teams.
Teams 1510 and 2898 - Student 2010-2012
Team 4488 - Mentor 2013-2016
Co-developer of RobotDotNet, a .NET port of the WPILib.
Unread 16-02-2014, 08:29
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: Sidecar Brownout causing motors to move
Thad,
If the DSC was browning out so was everything else on the robot. All bets are off when that occurs. Most often the DSC power supplies start to fail at about 5.5 volts, the PD power fails at about 4.5 volts. If there is a sudden surges, a lot of noise is generated in all of the control systems. I have not heard of a brownout fault with the Talons, but you might want to check with Mike at Cross The Road.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 16-02-2014, 08:39
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
Yes, this seems like an expected behavior:
The robot is enabled and you're driving it around. This means that the cRIO is sending PWM signals to the motor controllers via the Digital Sidecar with nominal high pulse width of 1.5ms (neutral) +/- .5ms (forward and reverse respectively). So you're in the middle of sending one of these pulses, and the Digital Sidecar browns out and stops sending the high signal so you have a pulse that is much shorter than what the controller was trying to send.
Some tests we've done with some of our Talons and a pulse-width generator show that they will respond to a signal much shorter than 1.0 ms with full reverse. So your truncated signal is interpreted as full reverse. The Talon then looks for another pulse for a little bit, but doesn't get one so it disables the output.
Unread 16-02-2014, 12:12
Rookie Year: 2010
That was exactly our thought too. We just wanted to double check and see if there was something else wrong with something else on the control system. We know to not brown out, and will make sure to have a charged battery to control it.
