Go to Post Pretty robots, who cares? Quality robots are another matter. - Steve W [more]
Unread 16-02-2014, 09:09
chris.boyle's Avatar
chris.boyle chris.boyle is offline
Programming Mentor
FRC #0068 (Truck Town Thunder)
Rookie Year: 2012
chris.boyle is on a distinguished road
8 Slot cRIO deployment issues
I'm getting the error below when I try to deploy our code to an older 8 slot cRIO. The code runs just fine if I run it from my laptop. I've tried reformatting it just before I deploy it, still get the same error.
2014 Chairman's Award--Michigan State Championship
2014 Chairman's Award--Waterford District
2014 Winner--Great Lakes Bay District
2013 Chairman's Award--Kettering District
2012 Championship Division Finalists--Thanks 330 and 639
Unread 16-02-2014, 09:13
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
Re: 8 Slot cRIO deployment issues
Check the dip switches.
Unread 16-02-2014, 09:17
Does the cRIO reboot? That is unfortunately, not an error I've seen during deployment.
I suppose you could go to Tools>>Options and to the VI server tab and ensure that TCP option is enabled. You can also do that on the Target Properties in the project. That is what it is complaining about, but I'm not sure why. Please let me know if that changes anything. You may also want to see if you can ignore the error, as it seems that the deployment succeeded, but perhaps was unable to access the controller afterwards for some cleanup step.
Greg McKaskle
Unread 16-02-2014, 09:49
Programming Mentor
Rookie Year: 2012
I did replace the ip listed with "*" to the machine access list of the VI Server page. It had no effect. I've seen this now on two different 8 slot cRIO's. All of our 4 slot are still being used in older robots.
As for trying to ignore the error, I can close the error message and when then the cRIO reboots, there is no code running. I'm deploying it by selecting 'Run as startup'.
Unread 16-02-2014, 17:41
bvisness's Avatar
bvisness bvisness is offline
Programming Mentor, Former Driver
FRC #2175 (The Fighting Calculators)
Rookie Year: 2010
bvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of light
I suppose you could always try re-imaging...
