Thread Tools |
Rating:
Display Modes |
Re: Wrecked Aluminium from chopsaw
Non ferrous cold saws are up in the 2000-3000 RPM range |
Just set it up right so you force everyone to use it right. Also I really dislike JET. It starts out fine and becomes a huge hassle to maintain. |
Without your setup forcing everyone to do it right, how could someone do it right by themselves anyways? What are some examples of doing it wrong, and what would be the consequences?
Material setup can vary from saw to saw. I setup a piece of angle wrong in a chop saw and received an open fracture in my left middle finger for my mistake. I used a setup recommended for a saw that was nearly the same, but not quite... Read the saw-specific manual for setup guidance and clamp everything down in some form. |
If there is a way to get 5 thou on a first cut though, especially on lengths exceeding my cheaper 8" calipers, I'd be all ears :0 |
I may have a slight obsession with my collection of calipers. 35" Vernier $150 Auction 18" Dial $180 Amazon (if you are cleaver with measuring you can get parts accurate to around 36" with these) 12" Dial $85 Amazon 6" Digital $35 Amazon 1" Vernier Mic $150 for a 0-1,1-2, 2-3, 3-4, 4-5 Starrett set from Craigslist ![]() |
Do you have a picture of how you set up your work stop and such? That seems like it would be really useful to get that last bit of precision out. On the topic at hand: I despise using the chop saw. We have one of the Dewalt ones somebody linked to early on in the thread, and "loud" doesn't begin to describe the hell-scream it emits when somebody turns it on. The ultra high rpms and plastic clamping system doesn't help its case either, although to be fair I've never had stock flip out on me. The only time I use it over the bandsaw is when I have to cut super long stock (because, as I mentioned above, I can't get it to within 0.005" on the saw alone). Having a massive floor bolted bandsaw helps. Last edited by asid61 : 14-06-2016 at 00:20. |
#10
I use a couple of the dewalt saws at work for cutting steel. I also used a similar one in High school (including on one occasion while on 1747). They work and when used for the right application can cut fast flat cuts. However, they heat the material a lot (since it's an abrasive saw) and they are loud (which isn't an issue at work since we all have earplugs in anyway).
