Go to Post Turning is overrated - Allison [more]
Unread 16-02-2014, 17:29
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Rookie Year: 2012
rich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond repute
Picking up ball and G26-1
G26-1 states:
ROBOTS may not break the planes of the openings of the opponent’s LOW GOALS.
Violation: FOUL. If extended, strategic, or repeated, TECHNICAL FOUL.
At today's practice match, an inbounded ball ended up against the opponents low goal. Unless you are very careful, the bot may break the plane of the opponent's low goal while trying to get the ball.
I think there should be an exception to G26-1 when:
1) Robot is trying to pick up its alliance's ball;
2) Breaking of the plane is incidental to picking up the ball; and
3) The breaking of the plane does not interfere with the other alliance attempt to score.
In the event of a violation where #1 and #2 apply, and #3 is violated, the opposing alliance is awarded the low score (and bonus points - truss, catch, assist, etc.), and if the ball is still on the field, another cycle is deemed to have begun.
There is a similar problem with rule G21. If the ball is against the edge of the field, if the robot comes to the ball perpendicular to the field edge, the ball retriever may extend past the ball and over the edge of the field.
I can appreciate the spirit of G26-1 and G21, but the design of the game makes that type of infraction easy to do, but not a real hazzard.
