Go to Post You mean how many Edible Data Analysis Metrics and Aggregated Measurable Entities (EDAMAME)? - Andrew Schreiber [more]
Unread 16-02-2014, 22:21
ThunderPorpoise's Avatar
ThunderPorpoise ThunderPorpoise is offline
AKA: Benjamin Hollinger
FRC #4373 (RooBotics)
Rookie Year: 2012
ThunderPorpoise is an unknown quantity at this point
Power Draw
Our team has been plowing ahead but we've run into a bit of an problem.
The motors that we are using for our catapult are behaving a bit inconsistently because, we believe, the draw from the battery is momentarily too great. We've thought about capacitors, but we're not sure they're legal. Has anyone else run into a similar problem or does anybody have an idea for how to solve this issue?
Unread 16-02-2014, 22:28
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
Re: Power Draw
Capacitors are not inherently illegal, but they would be considered custom circuits, and as such, can not "alter power pathways" including those feeding motors and/or motor controllers.
The best thing you can do is monitor the battery level in code using DriverStation.getBatteryVoltage();, and account for a lower voltage by increasing power. Older batteries can also lose voltage faster, so only use healthy batteries in competition.
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
Unread 16-02-2014, 22:37
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: Power Draw
Without further detail, it sounds like your motors may not be geared properly.
You can reduce momentary current surges by using a slew rate limiter in your code.
Unread 16-02-2014, 23:02
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Rookie Year: 2012
Gregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond repute
Re: Power Draw
Have you calibrated your speed controllers?
What are nationals? Sounds like a fun American party, can we Canadians come?
“For me, insanity is super sanity. The normal is psychotic. Normal means lack of imagination, lack of creativity.” -Jean Dubuffet
"Insanity is doing the same thing over and over again and expecting different results." -Albert Einstein
FLL 2011-2015 Glen Ames Robotics-Student, Mentor
FRC 2012-2013 Team 907-Scouting Lead, Strategy Lead, Human Player, Driver
FRC 2014-2015 Team 1310-Mechanical, Electrical, Drive Captain
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 17-02-2014, 08:23
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: Power Draw
Capacitors are legal for noise suppression only. You could not find a big enough capacitor to hang on a motor to help if brownout is the issue. And then it would only work if your motor was just spinning in one direction. Large caps usually are not bipolar. It is possible that you are tripping the breakers feeding the motors or that the controllers are faulting. A common issue for long runs is to use too small a wire gauge. There can be considerable voltage dropped across smaller guage wire.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 17-02-2014, 11:22
Ether's Avatar
Rookie Year: 1969
Re: Power Draw
No, they're not FRC legal in that application.
Yes, in theory you could put a capacitor across the motor controller's power inputs.
But let's do a very rough back-of-the-envelope calculation.
Let's say you wanted the capacitor to provide 40 amps for 1/4 second to mitigate the current surge. That's 10 Coulombs of charge.
Let's say the capacitor started at 12 volts (fully charged) and you want the capacitor's voltage to be no lower than 11 volts after discharging that 10 Coulombs.
What's capacitance would be required?
C = dQ/dV = 10/1 = 10 Farads.
Let's put 10 Farads into perspective.
See that big blue capacitor at the top of this image? It's 45,000 microFarads. It's 5.7 inches long and 1.7 inches diameter.
It would require 220 of those wired together in parallel to give you 10 Farads.
Or, for only $250, you could wire 10 of these in parallel to get a 10Farad 20V capacitor.
Unread 17-02-2014, 12:13
Unsung FIRST Hero
Rookie Year: 1996
Re: Power Draw
I wonder what the ESR would be?
Al
WB9UVJ
www.wildstang.org
Unread 17-02-2014, 12:35
Ether's Avatar
Rookie Year: 1969
Re: Power Draw
Good point. I was looking at very rough back-of-the-envelope best-case calculation, to show how impractical it would be.
I updated the supercap to emphasize that.
