Go to Post Once you have reached overkill, more is not useful. - DonRotolo [more]
Unread 17-02-2014, 00:14
NWChen's Avatar
NWChen NWChen is offline
Alum
Rookie Year: 2012
NWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to beholdNWChen is a splendid one to behold
Controlling 12V lights via arduino
We have a set of these 12V LED light strips that we'd like to control using a (5V) arduino.
With these LEDs each color (RGB) is a ground, and there's one lead for 12V voltage.
I'm assuming that the LEDs would go straight to PDB or through a relay (either way 12V), and then have power adjusted by the arduino. How can we control these LEDs, in a manner similar to this, using an arduino or similar device?
Unread 17-02-2014, 00:18
Nirvash's Avatar
Nirvash Nirvash is offline
AKA: Bryan
FRC #4676
Rookie Year: 2011
Nirvash has a spectacular aura aboutNirvash has a spectacular aura about
Re: Controlling 12V lights via arduino
With 'dumb' LED strips that just have a common positive terminal and negative terminals for the three colors, you wont get the individually addressable LEDs as show in the video, but you still can control the color of the entire strip.
See this,
http://bildr.org/2012/03/rfp30n06le-arduino/
and
http://www.jerome-bernard.com/blog/2...by-an-arduino/
Team 3488 - Electrical Lead/Programming Lead 2011-2013
Team 4676 - Electrical/Programming Mentor 2013-Present
Unread 17-02-2014, 00:28
NWChen's Avatar
Alum
Rookie Year: 2012
Would we achieve the same effect by controlling each color with a relay, or with a motor controller (to achieve a fading effect)?
Unread 17-02-2014, 00:38
Nirvash's Avatar
AKA: Bryan
FRC #4676
Rookie Year: 2011
If controlled by a relay, the strip can only have RGB channels in the full on or full off state, which would give you limited colors and no fading.
With a motor controller (or MOSFET) you get the full range of output from every RGB channel, this gives you thousands of colors and the ability to 'fade' the strip.
The bildr post I linked explains how to do this with a MOSFET and a PWM signal from the arduino.
Unread 17-02-2014, 00:53
juchong's Avatar
juchong juchong is offline
Electrical Engineer
AKA: Juan Chong
FRC #2655 (Flying Platypi)
juchong is a jewel in the roughjuchong is a jewel in the roughjuchong is a jewel in the rough
Here's a tutorial for controlling LED strips using MOSFETs and an Arduino. It even includes part numbers, wiring diagrams, and code!
http://learn.adafruit.com/rgb-led-strips/usage
Teams I've worked with:My Website: http://www.juanjchong.com/
What I do: Analog Devices iSensor Product Engineer
Unread 17-02-2014, 01:09
om_nom_nom om_nom_nom is offline
AKA: Nam
FRC #0708 (Hardwired Fusion)
Rookie Year: 2012
om_nom_nom is an unknown quantity at this point
This may not be of much assistance, but you could consider wiring them to a pneumatics bumper and treat the LEDs as solenoids. My team is doing something similar to this, and we have yet to have much issue. You would have one relay for each colour, and power each as needed for different colour combinations.
