Go to Post Why aren't the kids who sit alongside the sidelines and observe as valued? Why are they looked upon as leeches, in it for a trip? - Madison [more]
Go Back   Chief Delphi > Other > Math and Science
Unread 17-02-2014, 11:57
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Math Quiz: Parabola Path
The center of a circle of radius=1 traverses the parabolic trajectory.. y = -0.0433*x2.. from x=-5 to x=+5 in the XY plane, and as it does so it "sweeps out" a path with upper and lower boundaries.
Find the equations for the upper and lower boundary curves.
Unread 17-02-2014, 16:25
Ether's Avatar
Rookie Year: 1969
Re: Math Quiz: Parabola Path
Hint: the answer is not
Code:
y = -0.0433*x2 + 1
and
y = -0.0433*x2 - 1
Name:	not + - 1.png
Unread 17-02-2014, 18:08
Qbot2640's Avatar
Qbot2640 Qbot2640 is offline
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Rookie Year: 2012
Qbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond repute
I get:
Top curve: y = -0351x^2 + 1
Bottom curve: y = -.0433x^2 - 1
2012 Palmetto Regional Winners (Thanks 2059, 2815, and 287).
2012 Newton 14th Seed
2013 Chesapeake Regional Imagery Award Winners
2014 North Carolina Regional Imagery Award Winners
2014 Greater DC Regional Team Spirit Award Winners
2015 North Carolina Regional Finalists (Thanks 3971 and 587)
Unread 17-02-2014, 18:29
Ether's Avatar
Rookie Year: 1969
Originally Posted by Qbot2640 View Post
I get:
Not. See my previous post.
I get:
I assume there's supposed to be a decimal point before the "0".
Nice try, but no cigar.
Unread 17-02-2014, 18:40
Qbot2640's Avatar
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Rookie Year: 2012
My mistake...I had all three equations together, and grabbed your original as the "bottom". The top I got (as you corrected my missing decimal) is 0.0351x^2 + 1
The bottom I got was 0.0474x^2 -1
I calculated two normal lines and found points that were 1 unit away from points on your given original. Then calculated the quadratics from the two sets of three points (although the y intercepts being known, one really only needs two points).
Unread 17-02-2014, 19:16
Ether's Avatar
Rookie Year: 1969
The top equation y = -0.0351x^2 + 1 is still not right (even with the required "-" sign added back in )
The bottom equation y = -0.0474x^2 - 1 (with the "-" sign added) is a very good approximation in the given range, but as you can see in the attached graph, it diverges outside that range.
You've got the right general idea.
Then calculated the quadratics...
Hint#2: the top and bottom boundary curves are not true quadratics.
Unread 17-02-2014, 19:24
Ether's Avatar
Rookie Year: 1969
Graph of upper and lower boundary curves
Unread 03-03-2014, 00:02
RyanCahoon's Avatar
RyanCahoon RyanCahoon is offline
Disassembling my prior presumptions
FRC #0766 (M-A Bears)
Rookie Year: 2007
RyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond repute
Can I give the answers in parametric form?
Spoiler for parametric plot equations:
xlower(t) = t - 0.0866 t / √(1 + (0.0866 t)2)
ylower(t) = -0.0433 t2 - 1 / √(1 + (0.0866 t)2)
xupper(t) = t + 0.0866 t / √(1 + (0.0866 t)2)
yupper(t) = -0.0433 t2 + 1 / √(1 + (0.0866 t)2)
FRC 2046, 2007-2008, Student member
FRC 1708, 2009-2012, College mentor; 2013-2014, Mentor
FRC 766, 2015-, Mentor
Unread 03-03-2014, 09:51
Ether's Avatar
Rookie Year: 1969
You got it
Reps to you !
Unread 06-03-2014, 17:57
Ether's Avatar
Rookie Year: 1969
Is it possible to represent Ryan's parametric equations in explicit form y=f(x) ?
Or even implicit f(x,y)=0 ?
Unread 11-03-2014, 16:45
Ether's Avatar
Rookie Year: 1969
Does anyone have access to Mathematica?
Unread 02-03-2014, 20:40
Ether's Avatar
Rookie Year: 1969
Any math/physics teachers want to give this a try?
