Go to Post You won't find anything in school that says you have to share ideas or strategy with your football rivals. - Al Skierkiewicz [more]
Unread 17-02-2014, 13:31
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
Compressor Rule Question
This may have been answered somewhere but I couldn't find it on CD from this year or in the Q&A:
Are we allowed permitted to use an off-board compressor (powered via on-board relay and robot batteries) to fill our tanks pre-match, which is exactly equivalent to a compressor on-board, then use the on-board compressor during the match, or will this violate R79? Only 1 compressor would be plugged in and used at any given time.
This is the proposed setup:
- Prior to match, on-board relay connected to offboard compressor, connected through purge valve
- After filling tanks, disconnect offboard compressor and plug same relay into on-board compressor
The reason I don't see this as violating R79 is because one and only one compressor is ever plugged into the robot (effectively when pumping with the off-board, the compressor sitting on the robot is disconnected and dead weight). This would be equivalent to using the off-board as a spare part.
The reason we wanted to do this is the compressor gets extremely hot, and we want to go into a match with a cool compressor. Adding a large heatsink takes up space and weight.
I consider the setup above equivalent to a scenario in which you fill up tanks with an onboard compressor, that compressor is rendered broken, and a new, cool compressor is introduced as a replacement part prior to the match. Surely this scenario would be legal?
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
