Go to Post I wonder if Radio Shacks all over should prepare for VEX robots dropping by for spare parts just like people going to a medical clinic... - Wayne C. [more]
Unread 17-02-2014, 16:15
Akolbi Akolbi is offline
FRC #4607
Akolbi will become famous soon enough
how to wire the compressor?
I need to wire the compressor and the switch for it. how do i do this? i got the compressor to work, but the switch didn't affect it at all, and it ran while disabled.
what wires do i plug where?
Unread 17-02-2014, 16:19
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
Re: how to wire the compressor?
The compressor is connected to the outputs of a Spike relay. The pressure switch is connected to the Digital I/O section of the Digital Sidecar.
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
Unread 17-02-2014, 16:23
FRC #4607
what do i connect on the sensor end?
Unread 17-02-2014, 16:27
Taylor Hawkins Taylor Hawkins is offline
2386 BCHS Trojans
FRC #2386 (Trojans)
Rookie Year: 2010
Taylor Hawkins is an unknown quantity at this point
The sensor connects between the (-) Negative pin and the Signal pin of the digital side car DIO slot that you designate. I believe it doesn't matter what terminal in the sensor the wires connect to, just connect the negative to one terminal and the signal to the other terminal on the pressure sensor.
Hope this helps
Taylor
Unread 17-02-2014, 16:32
cgmv123's Avatar
AKA: Max Vrany
Rookie Year: 2011
Technically, the C terminal on the sensor should be connected to the GND pin on the DSC and the NC terminal on the sensor should be connected to the SIG pin on the DSC, but it doesn't matter since the switch is just closing a contact.
Unread 17-02-2014, 16:35
2386 BCHS Trojans
FRC #2386 (Trojans)
Rookie Year: 2010
Thank you for clarifying that. I didn't have one in front of me to give that information.
