Go to Post Please drill responsibly! - IKE [more]
Unread 17-02-2014, 17:41
smcmahon's Avatar
smcmahon smcmahon is offline
The Architect
AKA: Sean McMahon
FRC #2656 (QUASICS)
Team Role: Coach
smcmahon is an unknown quantity at this point
Window motor limit
Is it TWO rights and TWO lefts, or TWO total window motors?? We're confused now!
FRC 2656 | FTC 5526 | VEX 9656
Unread 17-02-2014, 17:44
smcmahon's Avatar
The Architect
AKA: Sean McMahon
FRC #2656 (QUASICS)
Team Role: Coach
Re: Window motor limit
Clip of <R 29>
Unread 17-02-2014, 17:47
Redo91's Avatar
Redo91 Redo91 is offline
AKA: Justin
Redo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of light
From R29 you may only use 2. Where is your confusion coming from?
Team 1296-Full Metal Jackets
Alumni 2009
Mentor 2009-2014
Team 624-CRyptonite
Mentor 2014-2015
Unread 17-02-2014, 17:49
smcmahon's Avatar
The Architect
AKA: Sean McMahon
FRC #2656 (QUASICS)
Team Role: Coach
Since they list four different kinds of motors there (seat, van door, window, etc) and it says TWO, the kids think that's two of each. They say since the window motors have two separate part numbers, that we can use two of each of them.
I disagree. Hence this post.
Unread 17-02-2014, 17:53
Redo91's Avatar
AKA: Justin
Have them read the blue box below R29, that should clear things up.
Alumni 2009
Mentor 2009-2014
Team 624-CRyptonite
Mentor 2014-2015
Unread 17-02-2014, 17:57
smcmahon's Avatar
The Architect
AKA: Sean McMahon
FRC #2656 (QUASICS)
Team Role: Coach
Thank you! That DOES clarify for us.
