Go to Post I Don't like to think in the Box so i try not to make robots look like them. - Tytus Gerrish [more]
Unread 17-02-2014, 17:56
ndroboknight ndroboknight is offline
FRC #3120
ndroboknight is an unknown quantity at this point
Help with Compressor!!!
We have the Thomas brand compressor, model number 405ADC38/12. I'm using Java to program the robot. The Compressor seems to just refuse to turn on. I have tried to directly power the relay separately and the compressor still did not power. We know the compressor turns on because we powered it (quite sketchily but only for testing purposes) with a 9V Battery. Please give me some suggestions!
Unread 17-02-2014, 18:00
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Rookie Year: 1999
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
Re: Help with Compressor!!!
Do you still have the fuse in the relay?
If so, is the fuse still intact?
If not, replace it with a 20A breaker.
Unread 17-02-2014, 18:08
RamZ's Avatar
RamZ RamZ is offline
Project Manager & Driver
AKA: Ram Zallan
FRC #0004 (Team 4 ELEMENT)
Team Role: Leadership
Rookie Year: 2012
RamZ will become famous soon enoughRamZ will become famous soon enough
Are you sure you're coding it correctly?
Could you either post here or PM me it if you don't feel secure posting it publicly, I may be able to help, we're also using Java this year.
Team 4 ELEMENT
team4element.com facebook twitter instagram
Unread 17-02-2014, 18:55
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
Do the relay lights on the DSC come on?
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
Unread 17-02-2014, 19:31
FRC #3120
The relay does currently have a fuse in it. We have tried replacing the fuse of the relay and replacing the relay altogether. I am not 100% sure if I am coding it properly. I have attached the subsystem class for the Pneumatics. And the lights on the sidecar did not come on. Could I know which ones are supposed to come on? Also I want to clarify that I tried to directly power the relay through code, not physically.
Unread 17-02-2014, 19:36
DDSLoan96's Avatar
DDSLoan96 DDSLoan96 is offline
Jack of all trades
AKA: Danny
FRC #1468 (J-Birds)
Rookie Year: 2010
DDSLoan96 is an unknown quantity at this point
On the digital side car check to see if you have 3 power LEDS on in the corner and also check to see if you get an indicator light by where you plug in the pwm for the relay. It should be green next to relay 1 based on what your code says
Unread 17-02-2014, 20:24
FRC #3120
No. The lights next to the relay on the Digital Side Car to not come on. We have also tried swapping out the Digital Side Car.
RamZ's Avatar
AKA: Ram Zallan
Rookie Year: 2012
I don't think you initialized your compressor correctly.
There are four necessary values.
Yours is currently "airCompressor = new Compressor(1,1);"
Ours is basically the same, except the values are (1, 1, 1, 1).
Try that out.
Team 4 ELEMENT
Unread 17-02-2014, 19:51
DDSLoan96's Avatar
Jack of all trades
AKA: Danny
FRC #1468 (J-Birds)
Rookie Year: 2010
There are three necessary values.
Ours is basically the same, except the values are (1, 1, 1).
Try that out.
I just took a look at the Javadoc for the compressor and I only see 2 constructors, one with 2 parameters(int pressureSwitchChannel, int compressorRelayChannel) and one with 4(int pressureSwitchSlot, int pressureSwitchChannel, int compresssorRelaySlot, int compressorRelayChannel)
Unread 17-02-2014, 19:56
RamZ's Avatar
AKA: Ram Zallan
Rookie Year: 2012
Yeah, sorry, I meant 4.
I just checked the code and realized that
Edited my above post, thanks!
Team 4 ELEMENT
Unread 17-02-2014, 20:11
DDSLoan96's Avatar
Jack of all trades
AKA: Danny
FRC #1468 (J-Birds)
Rookie Year: 2010
If Im not mistaken you only need the 4 parameter constructor if you are using multiple digital sidecars
Unread 17-02-2014, 20:12
RamZ's Avatar
AKA: Ram Zallan
Rookie Year: 2012
Not sure why we use the 4 parameters, but the compressor currently works. Hmmmm...
Team 4 ELEMENT
Unread 17-02-2014, 20:15
DDSLoan96's Avatar
Jack of all trades
AKA: Danny
FRC #1468 (J-Birds)
Rookie Year: 2010
My guess is that it defaults to 1 and 1 as the other 2 parameters when you only use one card.
Unread 17-02-2014, 20:21
FRC #3120
That was also our understanding. We have also tried the using the constructor with 4 parameters with no luck.
  #15   Spotlight this post!
Unread 17-02-2014, 20:23
DDSLoan96's Avatar
Jack of all trades
AKA: Danny
FRC #1468 (J-Birds)
Rookie Year: 2010
Do you have access to the robot at the moment?
