Go to Post if you want FIRST people to sign a petition, July isn't the best time to do it. - Pault [more]
Unread 17-02-2014, 20:32
drifter1310 drifter1310 is offline
FRC #3266
drifter1310 is an unknown quantity at this point
Solenoid isuues
So our solenoid is not switching our pistons back and forth. It compresses them but will not release that pressure when it is switched, it simply applies pressure in both directions. Has anyone had a similar problem or have a solution?
Unread 17-02-2014, 20:36
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Solenoid isuues
It sounds like the solenoid valve is plumbed incorrectly.
As if you have an exhaust port blocked.
Unread 17-02-2014, 20:42
FRC #3266
Re: Solenoid isuues
That doesnt make sense, because if that were true then it would let all the air out from the port that it should ave been plugged into.
Unread 17-02-2014, 21:33
FRC #3266
Re: Solenoid isuues
We fixed it by replacing the electrical plug in
