Thread Tools |
Rating:
Display Modes |
Re: Robowranglers 2014: Vader
I noticed a rangefinder on the front of the bot. Could that be an autocatch feature?
I would put my money on detecting ball acquisition in auto.
The team was inspired by the look of the intake to create a Star Wars theme. After deciding on the design, we voted on the robot name. Thus, Vader was born. We were inspired by the BOOM DONE intake, El Toro. After testing lots of different intakes, we decided that this design was best fit for all of the things we wanted to accomplish. As you can see, we are not the only team that felt this way. Quote:
We have two surgical tubing settings, one normal, and one we refer to as "The Force". The normal one is when the cylinder is retracted, and for longer shots we "use the force". Last edited by RachelDoby : 22-02-2014 at 16:47. |
So... I guess this means BJC was spot on. I just have to ask, why?
This is awesome. I appreciate the early post. The subtle changes over the "BoomDone" robot are awesome and are clearly well thought out. Good luck this year!
As to the why: every tried to get 5 legs of a stool all the same length? Articulating that wheel is necessary - pneumatically or otherwise. I'd guessing this is a way of not using more pneumatics. We have a little bit of familiarity with a slide-drivetrain. We tried one in 2008 but we hard-connected the wheels to the frame and quickly discovered why you absolutely MUST have mechanical compliance to insure all the wheels are on the ground. What they have here appears to be a refinement of their 2010 drivetrain. |
That makes so much sense. |
It's impossible to have all the wheels touch the floor at the same time, because the floor isn't perfectly flat. As a result, there are times where a non-articulated center wheel will be lifting one side of the drive train off the floor, so that you end up going in circles when you try to drive forward. I can't see the mechanism well, but I wonder if it doesn't use torsion springs to return it to level so it isn't touching the floor when it isn't running. Electronica1: I'd venture a guess that your drifting hypothesis is correct. They've seemed to enjoy drifting - I remember them doing it quite a bit in 2011. |
#11
Tumbleweed, Tornado, Armadillo, Raptor, Scorpion, Viper, Vader!?
#13
In awe!!
#14
I noticed that as well, why the deviation from the Texas theme?
#15
Raptor = Texas? Or Tornado? This isn't a deviation.
