R3 20" rule
After watching Suffield and some of the videos from New Hampshire, teams have different interpretations of the 20" outside the frame rule.
How do you define the 20" extension? |
Re: R3 20" rule
Re: R3 20" rule
How so? How did they see it differently?
Re: R3 20" rule
I'd like to know too. I thought the rule wasn't ambiguous and was pretty clear. Is there more than one way to interpret this rule?
Re: R3 20" rule
There's a good drawing of this on the frc-manual site. To accurately depict it, think of tying a string to the bumpers, able to move with 0 friction around the bumpers. cut it to 20 inches. That is the maximum external allowance!
That should get you close to the drawings provided! |
Re: R3 20" rule
Re: R3 20" rule
The rule says "a ROBOT may not extend more than 20 in. beyond the FRAME PERIMETER (see Figure 4-2 for examples) (see G24),"
It doesn't say a total of, it says up to 20 inches beyond the frame perimeter, with no additional restrictions. The vertical extension has an additional 6 inch cylinder restriction written into the rules. The image also shows a 20 inch box around a robot. It is all the way around, if you were only allowed 20 inches total, that box would be incorrect, it would only extend out 20 inches on one side. To go a bit deeper into FIRST game history, there was the year that you could extend one thing out past the bumpers. Teams built a single unit arm that came outside the bumpers as individuals and were not joined outside the bumpers until fully extended. Teams were connecting the ends with string to have their mechanisms be legal. It was a mess and a headache, and FIRST does learn from mistakes and issues in the past. Were there any head refs/lead inspectors/GDC members at the event that commented on this? Wetzel |
Re: R3 20" rule
Since we are not using 20" on one side can we extend to 40" on the other?
#10
Re: R3 20" rule
No...think of it this way: Draw your frame perimeter from above, then "offset" or project that perimeter 20 inches farther out (perfectly concentric with the frame perimeter). That offset is your "extension zone".
#11
Re: R3 20" rule
*112" rule was not taken into account while making frame perimeter. Last edited by Ty Tremblay : 18-02-2014 at 09:45. |
#12
Re: R3 20" rule
Seems pretty straight forward to me... |
#13
Re: R3 20" rule
Re: R3 20" rule
I have a question concerning weaher its just 20" form the side or weather that 20" also counts for the corner... rather than the 28" that would be found using the pothagorian therium...
#15
Re: R3 20" rule
It's 20" to the closest point on the robot. So the 20" would go diagonally to the corner, not perpendicular/parallel to the sides.
