Go to Post I know FIRST is all about changing society. But my approach is one person at a time. - Phil 33 [more]
Unread 18-02-2014, 10:23
Canon reeves Canon reeves is offline
FRC #4490
Rookie Year: 2013
Canon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud of
CRIO Pnuematics Module
So our team had a fairly last minute design and didn't start wiring the pnuematics till yesterday and we finished everything, except we don't have solenoid module that goes on the CRIO pnuematics module, we have everything done except one that. We have it where when we enable it pistons go out from the solenoid, but we can only pull them in manually. We were wondering if it was reasonable to put one on at competition and go from there? As in would there be enough time to do it all? I know what wiring it takes, just not what programming. We have it all programmed because we had another team help us we just don't have that last piece. Any ideas on what we could do? Thank you!
Unread 18-02-2014, 10:27
Wren Hensgen's Avatar
Wren Hensgen Wren Hensgen is offline
Alum, Mentor, Volunteer
AKA: Wren Hensgen
FTC #10353 (MetalWorks)
Wren Hensgen is a jewel in the roughWren Hensgen is a jewel in the roughWren Hensgen is a jewel in the rough
Re: CRIO Pnuematics Module
Are these 12 or 24 volt solenoids? If they're 12 volts, you can use a spike to trigger each one of them. 225 used a pair of spikes to trigger our shooter actuation last year.
It would also help to know what kind of solenoids you're using on your robot this year.
Unread 18-02-2014, 11:13
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
You can prepare all the wire in advance so you only have to wire the solenoid breakout. (The piece that plugs into the crio module). You can test your software without the breakout by observing the IO lights on the Crio output module.
With preplanning very easy to do at the competition.
Unread 18-02-2014, 12:09
FRC #4490
Rookie Year: 2013
Ok, thank you! It is a 24 volt solenoid, everything is ready to go, so we will just put on a solenoid breakout at comp. Thanks and good luck this season!
